Results 1 to 3 of 3
Thread: Cammed Ls1 FS/FT
09-07-2007, 03:24 PM #1Junior Member
- Mar 2007
- Buffalo
- iTrader
- 0
Cammed Ls1 FS/FT
Basically I get messed with everytime I pull out of my driveway with this car by the cops................
After getting arrested over some BS charges it needs to go.....................
I really could use the $$ as I have lawyer fees now but I will entertain trades/partial trades
I am pulling the car off the road next week to save on insurance and gas and to put towards my legal fund
asking $9500
1998
92,500 original miles
Florida car until 2003, no rust , stored winters
The car is a A4 hardtop with cloth interior, stripper in terms of options, it has pwr windows, pwr door locks, single cd monsoon, cruise, keyless with alarm, cloth manual seats, painted rims, no traction control ect
The car is a GU5 car , 3.23 rear gear ratio with aluminum driveshaft
The car is clean body wise, no dents or dings to speak of, it was involved in a parking lot accident and it had a drivers quarter put on, the job is almost factory perfect with the exception of the paint on the inside of the trunk isnt blended perfectly, it looks perfect from the outside, chances are most people would never notice but I am being up front, nothing else was damaged in the accident
It is one of the cleanest 98s you will find
The title and carfax are clean
Paint is nice, some small stone chips on the front clip, no large scratches or anything of the sort, shines up very nicely, I have had several people ask me if its a "new" car
It has a aftermarket ws6 hood that is made out of the same plastic composite the front fenders are and it is NOT fiberglass, painted to match the car
In the last 300 miles it has the following-
Torquer V2 cam on a 112lsa, comp prc double spring kit, chromoly hardened pushrods, ported ls6 oil pump, rollmaster double roller timing chain, yank ss4000 stall, b&m tranny cooler, new ac delco tranny filter with fresh dexron VI fluid, new u-joints, new serpentine belt, new front crank seal, had the front sway bar removed
All work was professionally done, all parts were bought brand new, I have all reciepts, over $3200 spent
It is professionally tuned for the cam , it runs very well and pulls very hard, it should easily put out close to 400rwhp now and run very low 12s if not high 11s
Other mods are-
Drilled and slotted rotors with red painted calipers, BMR weld in SFCs, BMR red STB, TSP Lid w K&N, Pacesetter coated LTs, TSP ORY, Magnaflow cat back, Delphi Maf, PCM tuned, no SES
It has new Goodyear Eagle RSAs on the front and new Mickey Thompson Et Street DRs on the rear
The car is very well maintained and is well cared for, oil has been Mobil 1 since 60k maybe before but was recently switched to Pennzoil Platnium, a K&N filter is used as well
I do not drive the car in the rain and it is garage kept and covered when not driven
Flaws-
rear window tint is peeling and needs redone and the plastic dash panel between the dash pad and windshield has a small crack by the A pillar
Other misc new parts-
Drivers pwr window motor
Headlight motors have been done before and currently work well
Replaced Monsoon speakers with ones out of a wrecked 12k mile trans am
Replaced tail light filler panel due to emblem fading with a new GM unit, no cheap sticker job
Replaced pwr antenna with one out of low mile wrecked car
Replaced several broken dash vents
The interior is clean, no rips, no tears, no excessive wear, owners have been non smokers, there are no burn holes in the interior, carpet is clean and is not ripped or stained, door panels are NOT cracked, everything works including AC
The car needs nothing and is turnkey and go, tranny has aprox 25k on it
All mods were done within the last 300-25k miles
It has been at a quarter mile track once and ran a 12.8@108 before the cam swap and stall
There were only 556 hardtop Formulas and 0 Trans ams made in 1998
It is one of 397 bright red 98 Formulas
Located aprox 20 miles south of Buffalo NY
09-17-2007, 06:25 PM #2
ill trade ya........lmao.....not that you'll go for it, unless u want a slower, not as loud version of yours
BIG RED
09-17-2007, 07:44 PM #3Junior Member
- Mar 2007
- Buffalo
- iTrader
- 0
sorry its sold
LS1 A4 vs. Cammed LT1 M6
By Mystic Z-28 in forum Kill StoriesReplies: 32Last Post: 04-14-2011, 04:48 PM -
My cammed C6Z
By clint195 in forum CorvetteReplies: 49Last Post: 03-28-2011, 12:54 PM -
Cammed '05 GTO
By CanadianGoat in forum Multimedia SectionReplies: 2Last Post: 02-02-2011, 11:29 AM -
LS3 cammed and LT = big boy
By djvaly in forum Multimedia SectionReplies: 3Last Post: 09-18-2007, 08:38 AM -
a4 ws6 vs m6 ws6 vs cammed lt1
By NiteRiderWs6 in forum Kill StoriesReplies: 10Last Post: 08-23-2007, 09:27 AM
