Results 1 to 20 of 21
09-06-2007, 03:37 PM #1
Borla adjustable or non adjustable?
Which one sounds better? And which one is louder?
09-06-2007, 04:00 PM #2Heinz
- Jun 2007
- Houston
Pewter- 2001 TA WS6
it's up to you which one you like. The adjustable is obviously the one that will allow for any options of sound. I went with the adjustable because I didn't want to get stuck with one sound if i didn't like it. I am running with a wide open plate. It produces the most aggresive sound, it is slightly raspy so if you don't like that, go with more restrictive plates. Does anyone know if running with the plates wide open takes away from the necessary back pressure needed for additional horsepower, or does the muffler present enough??
09-06-2007, 04:11 PM #3Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Get the adjustable with an electric cut-out.
09-06-2007, 04:21 PM #4
How loud is the adjustable with all of the restrictor plates taken out?
09-06-2007, 05:36 PM #5Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
It is fairly loud at least on my 94, basically becomes a straight pipe. I almost always used the middle plate just because I liked to hear my car but keep it a little subdued and a sleeper (was a B4C so had Camaro badges). Supposedly the middle plate is the best for power as well. Though in another 94 that had the same exhaust we swore it was better wide open.
I would say go with the adjustable myself, is a great exhaust and I am hoping to get another for the 02 biggest drawback is the price.
09-06-2007, 05:51 PM #6Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
09-06-2007, 05:57 PM #7
Adjustable , no plates, LT's w/high flow cats, pretty loud and very raspy. So raspy that I had a muffler delete pipe made to go in place of the Borla Muffler, and mounted an SLP LoudMouth II muffler in the intermediate pipe just ahead of the axle. Happy with that set-up.
2002 Sunset Orange TransAm 6 spd.
http://www.mustangmods.com/data/1327/dadsigpic2.jpg
09-06-2007, 06:56 PM #8
I run stock exhaust manifolds, cats and Borla adjustable with the plate that is 2nd only to wide open. I think it sounds good (will like it better with more mods!). People at work tell me it is loud (loud is relative). It is not obnoxious where I get sick of it on a long highway trip. You may want to consider an adjustable if you live in area where the police crack down on noise violatons.
09-06-2007, 09:57 PM #9
Yeah, I want to be heard but the FUZ really give us teenagers a hard time about noise.
So what restrictor plate would you put in a adjustable borla to make it comparable to a non adjustable?
And do they have pretty much the same tone?
09-06-2007, 10:13 PM #10Member
- Jun 2007
- Dalzell, Illinois
red with black stripes- 2002 Trans Am WS6
I have the adjustable with the wide open cutout, sounds good. little louder than the second biggest open, wich sounds good too. What size cutout is it? Putting headers on next week and dont want real loud, but want to be able to make it loud with a flip of a switch.
09-06-2007, 10:59 PM #11
09-07-2007, 06:43 PM #12
Does the adjustable have the same BORLA tone as the non adjustable? Because the louder of the two tailpipes does not go through a muffler.
09-08-2007, 01:59 PM #13
Tgis page may give you some ideas...
http://www.ls1sounds.com/
09-09-2007, 08:27 PM #14
09-10-2007, 05:01 AM #15Member
- Mar 2007
- Pittsburgh, PA / State College, PA
Silver- 2000 Trans Am WS6
The Borla adj sounds much better, plus u can change the sound with the plates to the sound u like best......I have a blowmaster exhaust my car right, it sounds really good but I hear it flows like crap, actually heard that it flows worse then stock.....My buddy has the Borla adj on his SS and it sounds mean as hell.....I'm def gettin the Borla adj for my car here soon....Anyone in here now the horsepower gains u get from a Borla adj catback????
2000 Silver Ws6 - Holly Powershot, MTI clear lid, MBA descreened 85mm maf ends, SLP bellow, SLP 160° T-stat, EGR delete, TB bypass, Elite Engineering PCV oil catch can, Sealed Ram Air, Diablo Predator, UMI SFC's, UMI Torque Arm, Borla adj cat-back
09-10-2007, 10:05 PM #16Heinz
- Jun 2007
- Houston
Pewter- 2001 TA WS6
gains are probably around 10-18 or so. I wouldn't go as far as 20. I noticed a little more throttle response, but really it's for the sound and then when you get more mods (cams, headers, heads) shit really starts to flow. I have my headers on order, ceramic y pipe, and high flow cats on my bedroom floor waiting for the other stuff. i want to get it dyno-ed and see where it's at. With a full exhaust you are probably looking at around 30 horses gained altogether with one mean ass growl.
09-13-2007, 09:27 PM #17
So I just bought the adjustable sytem and installed it. This sytem is my first mod to the car.
I put in the largest restrictor plate but it was still REALLY quiet. I'm not complaining at all. It sounds just like I thought it would. I just can't figure out why it is so quiet.
Although my friend has a magnaflow catback on his SS with headers and a ORY. His system sounds much better and louder than mine.
09-13-2007, 09:37 PM #18Senior Member
- Sep 2007
Not sure if you have tried this, but if you want louder there is one plate bigger then the largest restrictor plate. No plate at all
Also for louder remember the bigger the hole in the plate the louder the exhaust will sound.
09-13-2007, 10:58 PM #19
09-13-2007, 11:26 PM #20
FS Borla adjustable catback
By Ramairgod84 in forum Western MembersReplies: 19Last Post: 12-29-2009, 11:30 AM -
Wtb borla adjustable cat back
By fast droptop in forum Parts Wanted / TradeReplies: 0Last Post: 02-06-2009, 10:10 PM -
Borla adjustable catback for LS1
By rel3rd in forum Parts For Sale / TradeReplies: 0Last Post: 08-04-2007, 02:40 PM -
Needed: Ported LS6 oil pump, adjustable timing set, Adjustable Harland Sharps
By BraemerZ28 in forum Parts Wanted / TradeReplies: 0Last Post: 04-12-2007, 06:54 PM -
Borla Adjustable
By bwinch in forum Parts For Sale / TradeReplies: 0Last Post: 02-08-2006, 08:14 PM
Quiet or loud at the flick of a switch. That's the best of both worlds... and without having to crawl under the car to adjust.
