    PA
    2001 Z28
    mti clear lid w/dual nozzles, where to mount them?
    i have a clear mti lid and i'm going to try and mount dual nozzles in the neck, aiming them at the maf, BUT that damn IAT sensor is right there. should i mount the nozzle on that side(driver's side) infront of the iat, so i'm spraying past it, or in between the iat and the maf so that it's not spraying on the iat also?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    i did mine before the IAT.
    PA
    2001 Z28
    do you have any pics of your setup? i have the lid pulled and put the stocker on for now until i have the balls to try putting holes into my pretty lid. i was thinking about putting it about an inch behind the iat (towards the filter) and maybe notching the nozzle a little bit so that it sprays out more instead of right onto the sensor.
    d
    2002 z28
    ive seen them on the left and right side of the outer edges, where it is flat ( on the sides)
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by hallass View Post
    mine was a single nozzle. just out the other one opposite of it.
    PA
    2001 Z28
    thanks for the pic. i went ahead and drilled the holes today and i'm pretty much in the same spot, but it's just a hair closer to the iat since it sits out a little bit farther on my lid. now if the rest of the lines and other nozzle will show up i'll be ready to go.
  1. How To Install Nitrous Nozzles
    By Ed Blown Vert in forum General Help
    Last Post: 12-05-2013, 05:50 PM
  2. two nozzles to spray evenly?
    By jmatt07 in forum Nitrous
    Last Post: 03-23-2009, 06:19 AM
  3. Replies: 1
    Last Post: 08-27-2007, 04:21 PM
  4. NX dual nozzles or the new MAF kit from NX??????
    By greatwhiteZ28 in forum Nitrous
    Last Post: 03-02-2007, 12:01 PM
  5. Replies: 0
    Last Post: 02-05-2007, 03:06 PM
