09-04-2007, 12:32 PM #1
Broke my STFT and LTFT hystograms :( HELP
When I try to view my LTFT and STFT hystograms in HPT, I get text telling me that I must not have all the proper sensors setup. Which sensors are required to get ST & LT FT data?
Thx all... Gawd I feel like such a nub.
09-09-2007, 09:01 AM #2
go back to the default imperial config and look up both and see what parameters are needed to use them. also, did you remove anything from the table display?
09-09-2007, 01:32 PM #3
Trick was I needed the SAE sensor readings, not the non-SAE readings which read volts rather than kPa for MAP...
I was trying to get setup for MAF tuning, but failed mysterably. :-\
Thx mrr!
-Eagle
09-09-2007, 01:35 PM #4
let me send you my config file. it has MAF already set up in it. plus a bunch more stuff.
09-09-2007, 04:38 PM #5
09-09-2007, 04:40 PM #6
just sent it
09-09-2007, 06:34 PM #7
Got it! Thanks man!
09-09-2007, 06:40 PM #8
09-11-2007, 08:59 AM #9
I just started my MAF tuning. Only did one short log because it started raining but it isn't very far off really. I'm hoping to get that done this week sometime after work.
High LTFT's, Can not resolve, need help!
By jfl330 in forum Computer & TuningReplies: 13Last Post: 08-12-2011, 07:47 AM -
Walbro at 40 psi, 25% LTFT's
By mike171562 in forum General HelpReplies: 6Last Post: 08-11-2011, 10:16 PM -
Bank 2 ltft
By 20WS601 in forum Computer & TuningReplies: 6Last Post: 11-09-2008, 07:38 AM -
HPtuner tuning with LTFT and STFT???
By Firebirdjones in forum Computer & TuningReplies: 45Last Post: 01-30-2008, 04:18 PM -
Can someone look at these LTFT's..
By SeVeReDiStOrTiOn in forum Computer & TuningReplies: 2Last Post: 04-06-2007, 06:14 PM
