Page 1 of 3 123 LastLast
Results 1 to 20 of 49
    Aug 2006
    N.Hollywood
    98 Trans Am
    Question for A4 owners
    I have an A4 trans am and sometimes when I race my friends I like to down shift from D to 3, or 3 to 2 depending on how fast im going. My question is if anyone else does this on their A4, and could this potentially damage my transmission??? I dont do if often, but when I do it shifts great and feels smooth.
    Member sirenformula350's Avatar
    Chicago
    ha ha I did that all the time in my 89 formula. I have no idea if it hurts the tranny but it definitely made it seem like you are down shifting in a manual. Also if I was sitting at a light I would put the car in neutral so I could let off the brake. Wow, back in the day I wanted a manual so bad Sorry I wasn't any help though.
    Virginia beach
    SOM
    I do it alot hope it dont, lol
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    theres zero reason to shift an auto. you cannot out shift the ecu
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Chicago
    Quote Originally Posted by nhraformula View Post
    Yeah, you can't out shift the ecu but he is talking about down shifting. correct me if i am wrong but It seems like he is just doing it to slow down faster after racing or what not.
    Aug 2006
    N.Hollywood
    98 Trans Am
    I do it on the freeway, for example if im racing my friend, and were going around 60mph, i'll downshift from D to 3 and floor it for better acceleration rather than just flooring it on D which will accelerate much slower.
    Aug 2006
    N.Hollywood
    98 Trans Am
    I do it on the freeway, for example if Im racing my friend going around 60mph, Ill downshift from D to 3 and punch the gas for better acceleration, rather than flooring it on D which accelerates slower. hope this makes sense
    Rosebush, Michigan
    2000 Trans Am Ws6
    I have never tried it simply because I didn't want to mess anything up.
    Aug 2006
    N.Hollywood
    98 Trans Am
    If im on the freeway with my friend going around 60mph, ill down shift from d to 3 for faster acceleration rather than flooring it on D which will accelerate slower.
    Senior Junior Member warpwr's Avatar
    S.F. Bay Area
    2002 SS
    Say you are rolling start and the car has upshifted itself to overdrive or whatever.
    Then you will for sure beat the ecu if you put it into the gear you want to race in before you nail it.
    Or am I missing something here?
    Quote Originally Posted by breakking View Post
    when you mash the gas, it'll do what you want with no problems. If you wanted to shift, they make m6 models
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Let the tranny shift itself.
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Get a shift kit
    Aug 2006
    N.Hollywood
    98 Trans Am
    Whats a shift kit??? ARe they for A4???
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    yea dont down shift the only thing that can happen is BAD. leave in in OD(overdrive) and let it do everything for you. if you want harder and quicker shifts get a shiftkit, and a stall converter, go to a transmission shop and tell them what you want the car to do and they will make it happen
    Ontario, Canada
    yellow
    02 Collector Trans Am
    you can only get a shift kit for an automatic, so yet they are for an A4. The purpose is to make the tranny shift alot firmer, crisper and harder. They are installed in the transmission valve body so the pan must be removed and holes must be drilled into the valve body. The kit will come with instructions. Its not rocket science but you do have to be careful.
    Castle Rock, CO
    Montego Blue
    '07 BMW 328Xi Coupe
    I down shift only when I need to, I always feel like I have quicker response when accelerating by droping it down to the gear I want rather than mashing the gas. Plus I don't always like where the tranny is programmed to shift so I will purposely row the gears. Im sure my tranny is eventually gonna go but I could care less if it means I can do the conversion for the T56. Thats originally what I wanted for a tranny anyway.
    99 SS
    and IMO the 4L60 sucks
    Member VTR99's Avatar
    St. Louis
    2002 TA WS6
    Generally speaking automatic transmissions are pretty bullet proof. They are made shiftable for a reason, although racing isn't part of that reason. I have had automatics with manual valve bodies that had to be shifted just like a manual. The advantage being that they will outlast a manual clutch by about 4 to 1 or better. The disadvantage is that automatics are always a little slower than a manual with the same engine and gearing due to power loss. A shift kit will give you more solid shifts similar to a manual, but will also put more stress on the rear end.
    99 SS
    Quote Originally Posted by VTR99 View Post
    you have lost your mind
    i agree with everything else except the first about them being bullet proof, i went through 6 of the shitty 4l60's and never beat on the car, and that was in a time period of 6,000 miles with a mild HP car, my chevelle had about the same amount of HP as my camaro did and i never once replaced or rebuilt the TH350.. sorry i just do not agree with that statement...one thing goes wrong with an auto its pretty much game over for the whole thing.
  1. Question for 98 owners???
    By MNZ28 in forum Camaro / SS
    Last Post: 05-04-2010, 04:46 PM
  2. Question for GTO owners
    By Blackout99 in forum Firebird / WS6
    Last Post: 10-19-2008, 04:19 PM
  3. Question for WS6 owners
    By freddy_caprice in forum Firebird / WS6
    Last Post: 08-17-2008, 09:06 AM
  4. A Question For All You T-rex Owners
    By T's99BlackLs1 in forum Internal Engine
    Last Post: 02-15-2007, 09:08 AM
  5. Question for YZF R6 owners - What's your mpg?
    By nvmypwr in forum Almost Anything Goes
    Last Post: 05-01-2006, 10:03 AM
