Thread: Corvette fuel rail covers
11-07-2005, 01:17 PM #1Junior Member
- Oct 2005
- Turnersville, NJ
Black- 1999 Camaro Z28
I like the look of the corvette frc's. Do you have to modify them to fit a Camaro LS1? How do they mount? Thanks!
11-07-2005, 01:18 PM #2Member
- Jul 2005
- sc
Black, Red, Silver Jade- 00 WS6,95 Ta, 69 R code
you havr to cut for the fuellines the vettes only need one cut but the f bods need 2, and maybe a little trimming to fit over the throttle linkage...
2007 Yukon XL (sold)
2014 Z71 LTZ 3LZ (sold)
2010 Escalade Platinum AWD , 6.2
2017 Silverado HC , 4x4, 6.2
2000 WS6 ASC#2300 Holly LS6 intake, TR Custom grind cam, Mac Mids w/ ORY,Hotchkis LCA's, PHB, BMR Extreme STB, BMR re-location brackets,Eibach Sportlines, GMMG, Mccleod Pro 5.0, SLP SFC's, OEM ZO6 wheels
1995 TA
1969 R code Mach I my new project
11-07-2005, 01:42 PM #3Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Look e-bay and buy the precut ones.
11-08-2005, 07:20 AM #4
Yes, you have to modify them to fit.
Or modify the hell out of your car to make them fit.
Do what ever is easiest for you.
They attach to the fuel rail tube across the top of the manifold with built in c-clips in the plastic covers. They also attach to the small metal posts sticking up off the coil packs.
You have many options, ...
1) Buy a set form your local GM dealer for about $65-100 for the pair, depening on who you deal with. Or find them from sponsors on the website forums for about $50-60. Then you need to start looking at all the photos of the units that have been cut to fit & start you own cutting. Work your way into slowly, as it's pretty tough to add material back on to it if you cut too much.
#12556455, Right Side Fuel Rail Cover
#12559261, Left Side Fuel Rail Cover
These are the units with the two slots already in them. This is the best starting application. Do not buy the 99-up units with only one slot.
2) Buy a set that's already pre-cut for you. Make a couple small modifications under the hood & snap them in place. Shouldn't take but about 15 minutes to install for someone with some mechanical aptitude. Shold cost you about $90-110.
3) Order custom units that will blend with your plan under the hood. Painted to match the body color, or contrasting if you like. With decals of the vehicle type. These will cost you anwhere from $210-240+ depending on options. Been there, done that. Many times over, ..., for other people.
Good Luck, ...
ls1 corvette fuel rail covers
By SexyTransAm in forum Parts For Sale / TradeReplies: 2Last Post: 09-27-2012, 10:27 PM -
FS: Corvette Fuel Rail Covers
By Shepp1691 in forum Parts For Sale / TradeReplies: 11Last Post: 03-26-2009, 03:25 PM -
Corvette Fuel Rail Covers.
By taylorr12 in forum Parts Wanted / TradeReplies: 1Last Post: 12-05-2008, 05:56 PM -
WTB: SLP Lid for 01 WS6, Corvette Fuel Rail Covers
By cascade in forum Parts Wanted / TradeReplies: 3Last Post: 06-05-2008, 09:48 AM -
By 1959ls1 in forum Almost Anything GoesReplies: 4Last Post: 09-15-2006, 07:07 PM
