08-23-2007, 11:59 AM #1Junior Member
- Aug 2007
- temple ga
red- 1998 Z28
excess play in steering wheel at center
I have a 98 Z28, with 6speed, car has 2001 Z06 tires and wheels(275/40zr17 and 285/35zr18) When Im driving or sitting still, doesnt matter, my steering wheel sits at center, and has about 1/4" play to left or right before wheels begine to turn, and I feel resistance in the steering wheel as I should. My question is, what can I do about the excess play, is it a rack worn out, I found a new Rack assembly for 98 Z28, never installed for 310.00 plus shipping, also found many lesser expesive used racks, but worried that I might still run into same problem. What else should I replace? I am on a budget as I just bought the car. It drives very well, except at higher speeds that play can make it seem a little scary, you turn just a little as I am used to on my 95 Z28, and nothing happens, so I have to turn more than usual, and I have no choice but to use both hands as it seems that the excess play makes my hands move left to right as Im driving just from normal road vibration. I am used to a much more stiff steering wheel.
Car has 109k miles, and seems the previous owner has done some mods to the car, he has added frame connectors, SLP Cold Air Intake and Lid, angel eye headlights, as I stated the Z06 rims and Falcon Tires, Cat Back exhaust.
Any help would be appreciated.
08-24-2007, 08:09 PM #2Crazy Canuck !
- Jun 2002
- Montreal, CANADA
alignment would be my 1st suggestion.
Eugenio_SS
08-28-2007, 06:40 PM #3
yeah my 2000 ta does the same thing and not too long ago it actually slipped out while i was driving. Luckily I didnt crash or anything. All I did was jack it up and put it back together, it was fine until now I am noticing some more play in the steering. Tomorrow I am taking it in, and would suggest you do the same so u dont lose steering. I will find out tomorrow though.
08-30-2007, 12:18 PM #4Madeche Vision...soon
- Feb 2006
- Galveston, TX
NBM- '98 Ram Air Formula
Mine has a very similar problem and it is still there after a front end alignment. Was there something in particular that I should have asked them to do? I also heard something about setting the "preload". Not sure what that means???
Also, my kooks headers hit the steering linkage when in reverse, not bad just a little, but could that be the cause?
08-31-2007, 03:02 PM #5
http://shbox.com/1/4th_gen_tech2.html#rack_preload
Hope this helps. It worked for me.
New Rack/Pinion installed - now steering wheel is off center
By Neil in forum Suspension and HandlingReplies: 5Last Post: 03-12-2016, 09:41 PM -
Play The Steering Wheel Guitar While You Drive?
By LS1Powerhouse in forum Almost Anything GoesReplies: 26Last Post: 04-09-2008, 03:06 PM -
By voodoochi1d in forum DrivetrainReplies: 0Last Post: 08-23-2007, 11:35 AM
