    Member fxgs's Avatar
    Camp Hill, Pa
    Onyx Black
    2002 SLP Camaro SS
    SS is DEAD! HELP!
    2002 SLP Camaro SS............started up fine on Saturday.............drove about 20 miles, ran great..........parked for about 5 hours, got in and was completly dead, not even a click when I turned the key. Jump started and drove it home, ran fine.
    Tried to start next day, same story.
    A friend had a brand new Optima red top he gave me to try out..........put it in, car fired right up, ran great.
    Tried to start today, same story, completly dead.
    Any thoughts.............?
    Senior Member 02ultraZ's Avatar
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    Maybe a power wire is grounding somewhere and draining the battery.
    After the car has sat and you tried to start it and it doesn't fire up, test the voltage of the battery and see if it's getting drained.
    caraholic ggino85's Avatar
    most miserable city in the US
    blue green chameleon
    make sure the battery wasnt leaking. i had a very small leak in my battery before and it dripped along a wire, fried my starter or something and my car would do just that. start drive fine, then not start and then hours later start up just fine. hope you figure it out, good luck.
    2002 Formula Firehawk 96z28's Avatar
    San Diego CA
    youre battery is being drained. Check all grounding wires
    Camp Hill, Pa
    Onyx Black
    2002 SLP Camaro SS
    Thanx for everyones suggestions and help. Jump started the car again and let run a bit. When I shut it off, I heard a humming and realized it was coming from my electric H2O pump. Apparently there is an open circuit that lets it run when I shut the engine off, draining the battery. Going to trace the wiring and find the problem
    DFW
    '18 CTS-V
    '13 ZL1
    Alternator...check that out as well...
    Vicksburg, MS
    2002 Camaro SS
    check the hood light and glove box lights etc to see if they're stuck on... you got a drain, dude!
  1. He's dead, now what?
    By SHines-IT in forum Almost Anything Goes
    Last Post: 07-17-2010, 11:57 PM
  2. RMS is dead.....GO AVS !!!!!!
    By 98T/Aformula. in forum Rocky Mountain Members
    Last Post: 07-08-2008, 06:42 AM
  3. Dead MAF?
    By JwMonE99 in forum General Help
    Last Post: 12-27-2007, 01:40 AM
  4. E40 is NOT Dead!!!
    By LS2Tuner in forum Almost Anything Goes
    Last Post: 02-21-2007, 06:05 PM
  5. the T/A is Dead
    By NeXuS in forum Firebird / WS6
    Last Post: 11-28-2005, 06:55 AM
