Results 1 to 17 of 17
    Junior Member 0utLawTransAm's Avatar
    pensacola
    green with blue comeleon
    2000 trans am
    Talking number of dark forest green w/blue pearl t top
    i got a 2000 trans am fully load with t top it is a dark forest green the turns blue in sertan light i have only ever seen 1 other 1 i was wounder if this was a rare color ? any 1 have a build number for these thks
    Orig Regist: 9/98
    NE Indiana
    1998 Trans Am WS6 'Vert
    The color's name is "Blue-Green Chamelion". Not a very common color. This is all I have on 2000 production numbers (no color breakdown):
    2000
    Firebird 13529
    Firebird Convertible 1149
    Formula 1302
    Formula WS6 233
    Trans Am 6639
    Trans Am Convertible 783
    Trans Am WS6 7166
    Trans Am Convertible WS6 1025
    Total 31826
    Johnny B - '98 "Triple Black" WS6 Convert, M6, All Options, ASC #3030 (1 of 50)
    KBDDSFC, DGM C/F Tonneau, MTI C/F Lid, K&N, HPP-III, 160 T-stat, Pro 5.0
    Link to Firebird Production Breakdowns
    pensacola
    2000 trans am
    how do you tell what number you car is ? 1 - 6639 ? mine is a 2000 nut is was made in dec/99 so u think it would be in the lower 1000 ? so my color is rare ?
    Orig Regist: 9/98
    NE Indiana
    Quote Originally Posted by 0utLawTransAm View Post
    Well, without a detail breakdown there is no way to tell exactly. Additionally, non-WS6 cars weren't documented w/ a build#. But in '98 only 3.4% of the 9773 non-WS6 T/A coupes built were BGC (336), so if you rely on statistics and assume the same ratio of BGC cars were built in '00, then 3.4% of 6639 = ~228 estimated BGC T/A coupes built in '00.
    Probably explains why you don't see very many BGC T/As, I've only seen one other, a girl at work bought a '99 BGC T/A after she wet her panties riding in mine.
    LS1Fireback GreenBirdman's Avatar
    Feb 2007
    Kentucky
    Blue/Green
    99" TA LS1
    I have a 99 T/A the same color, I have seen one other on like mine, but it was a firebird,
    someday joejenkinsglass's Avatar
    Iowa
    green
    98 formula
    mines a 98 and it sounds like the same color as yours but I was told it was a 98 only color it is also similar to my 05 yukon which is called bermuda blue the car is more of a green the yukon is more blue
    Member KJax2010's Avatar
    Kokomo, IN
    Impulse Blue Metallic
    2005 GTO
    Quote Originally Posted by joejenkinsglass View Post
    That is true. In 1998 and 1998 only was Bright Green Metillac made along with Sport Gold Metallic and Purple.
    Heres 1998 production numbers:
    http://lair.evyl.org/1998-Firebird_P...on_Numbers.htm
    Iowa
    green
    98 formula
    Quote Originally Posted by KJax2010 View Post
    well acording to that mine is 1 of 34 98 formula a4 coupe
    pensacola
    2000 trans am
    mine is a 2000 and is same color as joejenkinsglass avatar pic in my pic but mine is a little bit rougher condition plus i just killed it the other note erg....
    Iowa
    green
    98 formula
    when I bought mine the color was ok but it has grown on me I do still like black with chrome wheels (even though everyone has a black one) that sucks you killed yours what happened? mine still looks the same but is not running for now at least I can still take the 01 ss vert for a ride when I have the need to burn rubber
    Member blackls1ta's Avatar
    kittanning,pa
    2000 ws.6 m6
    thaT COLOR is called mystic teal metallic i used to have a 95 lt1 ta that color stunning in sunlight very rare
    Orig Regist: 9/98
    NE Indiana
    Quote Originally Posted by blackls1ta View Post
    I thought "Mystic Teal" was the name Ford used for a similar color (green/purple) on the Cobras. Regardless, in '98 Pontiac called it "Blue Green Chamelion". They also offered a "Bright Green".
    38 of 139 PontiacFan's Avatar
    Kearney, NE
    2001 Pontiac
    So much mis-information, ..., *shakes head*
    No, Pontiac did NOT call the LS1 based Firebirds 'Mystic Teal'.
    It was called Blue-Green Chameleon as mentioned before.
    There was also a Bright Green, but this car mentioned in the first post appears to be BGC.
    The BGC was not a '98 only color. The Bright Green may have been tho.
    But the way the thread starter explains it, I would 'guess' it's BGC. But I wouldn't come right out & state it as fact without seeing more photos.
    Edit: Wow, Johnny, you musta been thinkin' the same thing, ..., at the same time. I was just slower on the tree, ...
    pensacola
    2000 trans am
    here is some more pic of the car i dont have any right now when it looks blue just the different shades of green it goes threw and this is deffently not TEAL at all i have seen the teal trans am and they look much deferent than mine as you can see from bottom pic i had motor out i thought i had spun a bearing turned out that my flex plate bolts started backing out so i fixed it and was drive and it happened agian but this time the trany flex plate and starter went with it
    pensacola
    2000 trans am
    there deffently not the same color i couldn't find a pic of a t/a but it the same teal they use on them
    Iowa
    green
    98 formula
    I bet pullin the engine from the top really sucked
    pensacola
    2000 trans am
    it wasn't to bad putting it back in was the hard part i pulled it i a day by my self know it looks like i might have to pull it again i just f**k something up really bad im hoping it just my trany that wont be to hard to replace im thinking of getting a 6 speed to swap it out but if i spun a bearing or broke a rod im going to get a 6.0 iron short block to put back in it and maybe some 243 heads on top
  1. options for dark green T/A
    By LT1 > LS1 in forum Appearance Section
    Last Post: 02-21-2009, 08:42 AM
  2. For Sale: 2000 Firehawk - Dark Blue - 70k mi - 6
    By JimmyTime in forum Vehicles For Sale / Trade
    Last Post: 12-08-2008, 11:29 AM
  3. Forest/Med Green Camaro's?
    By Spikito in forum Camaro / SS
    Last Post: 05-05-2008, 08:46 PM
  4. FEELER 2000 Z28 Dark Blue
    By Hodgesz28 in forum Vehicles For Sale / Trade
    Last Post: 05-15-2007, 10:10 AM
  5. Fiji Blue Pearl Trans Am!!!
    By Sonic99 in forum Firebird / WS6
    Last Post: 04-05-2007, 12:46 AM
