08-19-2007, 07:14 PM #1Junior Member
- May 2007
- NY
Red w/factory stripes- 02 camaro ss
ls2 based supercharged 402 in a F-body
Hi, I'm Jason. I am power hungry and I´m thinking very seriously about a LS2 based 402 aluminum short block low compression. Remember I´m going supercharged at 8-9psi, Heads and supercharged cam package. My actual LS1 is an 02 only 14K miles and it´s running great but I need more power. shooting for at about 600rwhp
Questions....
What do you think about this set-up?
What other parts do I need to make this?
Any vendor recommendations?
Any comments or ideas are welcome..
Thanks....
Jason
08-19-2007, 08:46 PM #2Junior Member
- Jun 2007
- Missouri
Silverstone Metallic- 1999 Chevrolet Camaro Z28
Heres a question..
will you sell me your old engine
08-20-2007, 04:10 AM #3Are you kidding? Jason, stick with your original engine! Such low mileage on your stock engine, it'd be an absolute waste. You can easily obtain those horsepower numbers with the LS1....
Originally Posted by twoss'sinny
08-20-2007, 04:34 AM #4running on empty
- Jul 2007
- Madison, WI
Black- 2000 Pontiac Trans Am WS6
yeah since the LS2 is really expensive know compaired to the LS1 I would just build up your LS1. you would get more bang for the buck.
08-20-2007, 05:07 AM #5Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Whatever you end up doing....building out your LS1 ( Is what I would do) or going the 402 route.....I would stick with the iron block if I went the 402 route.....
08-20-2007, 05:08 AM #6member since may 2000
- Dec 2002
- n/w chicago
well, youre looking at spending atleast 15k to set up the car for that power.
http://www.eastsideperformance.net/
http://www.rapidmotorsports.com/
above are some links to some well known ls1 tuners.2000 nhra edition formula
a few bolt ons, 379 rwhp
11.96 @113.25
08-20-2007, 07:58 PM #7Junior Member
- May 2007
- NY
I think easily is a stretch, I want to stay away from NOS, I dont want turbo lag, and I need it to be a daily driver in the summer so a big big cam is out. Also cant the stock bottom end only support up to 500hp I want 625-700 fly wheel hp..... can you get that much out of an ls1? I havent seen it!
08-20-2007, 08:06 PM #8Junior Member
- May 2007
- NY
08-20-2007, 08:16 PM #9
I would get he L92 heads. Ls7 flow numbers at discounted price. (i think it's about 175 per head, bare!)
08-23-2007, 11:04 AM #10
Why don't you put some forged, low-comp pistons, blower cam and ARP rod bolts in your LS1 and bolt up a F1 or Novi 2000? The factory crank is pretty tough and the Al block will be fine for the power levels you are looking for. My stock bottom end lived with 576rwhp/590rwtq for years and if you haven't seen 550-600rwhp out of an LS1, you haven't been looking very hard.
08-23-2007, 12:35 PM #11
08-23-2007, 01:27 PM #12No stretch whatsoever. You already stated that you wanted to employ a Supercharged 402, with a goal of 600-RWHP. You can easily meet that goal (and then some) with your existing LS1. Incidently, you don't need a giant cam to accomplish this lol, just one that will compliment the heads needed to attain such power levels, which is where the "true" power is found. Determine maximum boost, use this to determine desired compression level(s), have a custom reverse split cam ground to compliment whichever heads you decide to go with, then slap on your ProCharger. 600-RWHP will be an absolute UNDERSTATEMENT, believe me. As far as the stock engine's capabilities, as long as there is no detonation, you will be fine, so get a PROFESSIONAL tune....
Fluid Based Pulleys
By Squirly013 in forum External EngineReplies: 0Last Post: 02-26-2008, 03:19 PM -
looking for info/specs on LS-based motors
By SOLO Z in forum General HelpReplies: 2Last Post: 02-09-2008, 02:29 AM -
LS based Distributer
By texinteg in forum External EngineReplies: 17Last Post: 07-05-2007, 11:17 AM -
LS1 based Iron 6.0 Shortblock 750-800 Hp as is...
By Trickflowing in forum Parts For Sale / TradeReplies: 3Last Post: 06-22-2007, 08:16 AM -
Who is Colorado's fastest LSX based F-body?
By Blown 98 Z in forum Rocky Mountain MembersReplies: 28Last Post: 09-08-2006, 02:01 PM
