Results 1 to 20 of 25
Thread: stock ls6 block??
08-18-2007, 11:19 AM #1
stock ls6 block??
So i heard that the last 300 Camaro SS came with the LS6 block..
Did they do the same with the Last ws6's??? any1 know..
I have an 02 ws6.. How can i find out if i might have it???
08-18-2007, 01:42 PM #2
some later year 2001 f-bodies had them and all 2002 did
08-18-2007, 02:39 PM #3
08-18-2007, 02:58 PM #4
I have one Here are some tell tale signs. Look on the top of the block behind the water pump kin of underneath the TB on the passenger side. If you see a bullseye casting mark, you have an ls1. I you have none, you have an LS6. If you can look on the back of the block underneath the rear drivers side head and see the last four digits of 1168, you definately have an LS6
08-18-2007, 05:48 PM #5
08-19-2007, 12:56 AM #6
01 - 02 some got the LS6 blocks and blocks only because they temporarily shut down the LS1 block casting plants in Canada so a few got the LS6
08-19-2007, 08:01 PM #7
dont the 2001-2002's have ls6 intakes?
08-19-2007, 08:09 PM #8
yep, LS6 intakes and no EGR
08-22-2007, 04:38 PM #9
so they came wit the ls6 intake not block?
08-22-2007, 04:45 PM #10
08-22-2007, 05:07 PM #11I have one Here are some tell tale signs. Look on the top of the block behind the water pump kin of underneath the TB on the passenger side. If you see a bullseye casting mark, you have an ls1. I you have none, you have an LS6. If you can look on the back of the block underneath the rear drivers side head and see the last four digits of 1168, you definately have an LS6
08-22-2007, 05:14 PM #12
- Aug 2006
- Madrid, Iowa
red- 02 trans am ws6
It's right behind the head, kinda like a little lip. my blocks on a stand with no heads I could take a pic if that help?
WS6 with a LS6, true duals, headers, it's slow bla bla bla...
08-22-2007, 05:30 PM #13It's right behind the head, kinda like a little lip.
08-23-2007, 12:26 AM #14
08-23-2007, 06:02 PM #15
- Dec 2005
- Ontario
Mystic Teal Pearl- 1995 Trans Am
i know a buddy of mine that has a 2002 WS6 and he has the ls6 block and intake. apparently they ran out of the ls1s closer to the end of the production of fbodies so they used the ls6 blocks to finish the last cars.
all stock 312rwhp and 325ftq
08-23-2007, 06:21 PM #16
08-26-2007, 01:24 AM #17
- May 2007
- Seattle
Purple- 1998 T/A convertable
Is the Ls6 block a straight swap out for the ls1?
08-26-2007, 07:37 AM #18
ok im a but i thought they all had ls1's and the older ones had lt1's, i didnt think it even went up to 7, unless its not talking about engine or w/e im not sure can some explain to me???
08-26-2007, 07:44 AM #19
- Aug 2006
- Madrid, Iowa
yes the ls6 block is a direct swap.
08-26-2007, 08:19 AM #20
I found the article on the LS1/LS6 info, check it out!
http://smg.photobucket.com/albums/v1...VSLS6Block.jpg
How To Buy A Stock Chevy 350 Block
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 06-26-2013, 07:50 PM -
LS6 block stock in 01-02 TAs??
By Jorgens in forum Firebird / WS6Replies: 7Last Post: 07-19-2011, 04:49 AM -
Stock Ls1 block strength
By Allday1017 in forum Forced InductionReplies: 12Last Post: 06-08-2010, 07:50 PM -
5.3 block, stock LS1 rods etc.
By jjz28 in forum Parts For Sale / TradeReplies: 5Last Post: 04-14-2010, 10:00 AM -
best et stock ls1 block
By hotrodd in forum Almost Anything GoesReplies: 5Last Post: 09-01-2006, 10:21 AM
