Thread: 95 impala with t56!
08-16-2007, 08:28 PM #1Junior Member
- Aug 2007
- Bellingham
green- 1995 Impala SS
95 impala with t56!
I did the t56 swap not long ago, I used trans out of 96 camaro. everything went without one problem, except when we drove it trans started making this noise, the best way to describe it it is sounds like a diesel. Actually its not making any noise when its cold, when warms up it gets pretty load. When you depress clutch it goes away. So we figured bad bearings, replaced them. did not fix the problem. Transmission shop don't know what to do at this point. Thanks for any help!
08-21-2007, 08:57 AM #2Member
- metro Detroit area
What clutch are you using? Some aftermarket clutches are not "tuned" and allow vibrations of the motor to rattle the gears.You could try a little heavier oil if you don't drive in the cold weather with it.
08-21-2007, 07:07 PM #3Junior Member
- Aug 2007
- Bellingham
I am using stock clutch. What oil can I use besides ATF? The car was running out of gas this morning on the rack and the noise got worse. When it idles at 1000 rpm noise goes away. I've talk to Sixspeedinc, they sad its not a trans problem, something inside bell housing causing problem.
http://www.cardomain.com/ride/2096094
08-21-2007, 07:14 PM #4Junior Member
- Aug 2007
- Bellingham
I am using stock clutch. What kind of oil can I use besides ATF? It stops making noise when it goes up 1000 rpm. I talk to sixspeedsinc this morning they sad its got nothing to do with trans, something is wrong within bell housing.
08-23-2007, 03:57 AM #5Member
You can try synchromesh, its a blend that is higher viscosity(thicker) and works in a T56. There are two conditions I can think of that this will help. A roll-over rattle happens when the car is in idling in neutral. It will pick up a noise when warm that can sound like a diesel. A higher idle will help this as it is really just the transmissions reaction to an idle that is too low/ rough. There is also a condition that is called launch rattle. That is the transmission reaction to a clutch apply. As the clutch picks up it has a chattering affect on the trans and makes a noise.In this instance a quicker release of the clutch also helps. Both of these conditions are more of an anoiance facter rather than something you should worry about. As above, the synchromesh helps too.
08-27-2007, 09:23 PM #6Junior Member
- Aug 2007
- Bellingham
This morning we put thicker oil in, which solved the problem! Thank you 30thbird!
08-28-2007, 03:26 AM #7Member
Good thing. I don't know where Belingham is but if it gets cold there, you may want to do a winter oil swap to avoid cold shiftability issues. Cool car.
Question: impala ss
By kuwaiti78 in forum Road Racing / AutoXReplies: 8Last Post: 07-04-2011, 11:51 AM -
96 impala vs.everything i have
By trailblazer ssss in forum Drag RacingReplies: 11Last Post: 07-15-2008, 11:43 AM -
67 impala
By saint d in forum Vehicles For Sale / TradeReplies: 0Last Post: 12-17-2006, 06:06 PM -
11 sec. 95 Impala SS
By tntdiablo in forum Vehicles For Sale / TradeReplies: 0Last Post: 12-02-2006, 01:10 PM -
My Impala
By juicedimpss in forum Member's RidesReplies: 4Last Post: 09-06-2006, 12:03 AM
