08-12-2007, 04:00 PM #1
Rear Calipers-how do they back off
Just preparing myself for a rear brake job and i figured this would be a good place for an answer. How do the rear calipers back-off on these cars? I know some you just man-handle and use a prybar to get em back, and others you have to have th 'tool' to screw them back in etc. How do you get these ones to back off? Also, how does the parking brake affect removal? Special tools required or what? I've not done rear-disc before, i assume it to be the same as a set of fronts.
08-12-2007, 04:57 PM #2
08-12-2007, 05:04 PM #3Slow'er'Ass
- Thornton, CO
Same as the front.
They should just come off once the caliper bolts are removed. Keep a hand on it when removing the bolts...may just come off.
08-12-2007, 05:05 PM #4
Thanks, its just standard then. I wasn't sure if there was any special steps involved with the rears as they contain the parking brake end of things as well.
08-13-2007, 01:17 AM #52002 Formula Firehawk
- Jul 2005
- San Diego CA
Black- 2002 Formula Firehawk
I always keep the parking break on because the wheel is definitely not gonna rotate.
08-13-2007, 01:41 AM #6
The parking brake is a small set of shoes inside the rear rotor, completely independant of the caliper. Don't forget your 16mm to hold the caliper mounting nut while you turn the bolt and use a c clamp to compress the piston. BTW, I always recommend a complete flush of the brake fluid every couple of years, this may be a good time.
08-13-2007, 02:34 PM #7
08-13-2007, 03:24 PM #8
Yea, i wasn't sure HOW the ebrake actually worked, kinda my reason for asking all of this I suppose. I didn't plan on setting the ebrake to change 'em out though, lol.
Speaking of which, my ebrake doesn't work the best, replacing the shoes, tough task? Worth doing? Can i buy these pads anywhere or are they a dealer-only item?
08-13-2007, 03:24 PM #9
08-13-2007, 04:10 PM #10
adjust your parking brake if its not holding well. its HIGHLY unlikely its a problem with the shoes unless the following
A. the springs rusted inside and broke
B. the rotors were removed at one point and the friction material was ripped off the shoes.
To set the parking brake tighter some cars have an adjustment nut inside the handle that tightens up slack on the cable. other times there is a hole in the backing plate that allows you to set the drag using the adjuster wheel tightening up the shoes. either way dont overdo it. you should have your handle get tight fairly quickly.
to compress the caliper piston you can either use a clamp with the old pad in place or a nice big pair of channel locks. i use the channel locks myself. if you use the channel locks make you have the jaw applying pressure either on the pad or both sides of the piston. you dont wanna break the piston. this job is super simple. lastly dont forget to pump your pedal up so its nice and high and hard. check the fluid, and if your pedal is spongy you can go the extra mile and bleed the brakes.
08-13-2007, 04:52 PM #11
i've done brakes before!
I just wondered if these things were anything special and its obvious they aren't. Thanks for all the help
08-14-2007, 07:17 PM #12
Question: Back spacing for CTS-V calipers help please
By JoshuaGrooms83 in forum Wheels and TiresReplies: 2Last Post: 08-30-2010, 08:32 AM -
can i put put the front calipers on the back??
By ggino85 in forum General HelpReplies: 3Last Post: 07-11-2008, 07:24 AM -
Rear LS1 98-02 Rear Disc Backing Plates/Calipers/Brackets
By peetsjunkie in forum Parts Wanted / TradeReplies: 2Last Post: 10-02-2007, 08:53 AM -
rear LS1 calipers on eBay
By Justin0247 in forum Parts For Sale / TradeReplies: 1Last Post: 04-14-2006, 06:37 PM -
Lettering on rear calipers
By GottaHaveLS1 in forum Appearance SectionReplies: 9Last Post: 03-14-2006, 01:43 PM
