    the cake is a lie twozs's Avatar
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    rear gear lube and additive
    01 z 273 ratio w posi.(50,000 k original owner) what recomendations for replacement of the lube(weight) and posi additive if any. obviously synthetic .
    2 SS's are better than 1 Jays00ss's Avatar
    Lathrop, Missouri
    NBM / Silver
    00 SS / 71 SS Elcamino
    75w90 Royal Purple Don't need additive. Best by far you'll need to buy 3 qts because you need a little over 2 to do the job.
    Quote Originally Posted by Jays00ss View Post
    Painted manta stripe
    Member whiteLS1TA's Avatar
    California
    Artic white
    2001 Trans am
    i use redline. i just did the rear end fluid and the tranny fluid all i use is redline
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Mobil 1 75W-90. Didn't add the limited slip additive, Synthetic gear oil isn't supposed to need it.
  1. Question: 9 in detroit locker best gear lube to use
    By speedy30 in forum Drivetrain
    Last Post: 04-29-2012, 08:19 AM
  2. Torsen posi lube and additive?
    By Ortiz11b in forum Drivetrain
    Last Post: 08-23-2011, 06:25 PM
  3. Gear Lube
    By Sarge in forum Drivetrain
    Last Post: 04-10-2011, 01:26 PM
  4. Question: Gear oil additive?
    By izzhemp in forum Drivetrain
    Last Post: 05-19-2010, 06:41 PM
  5. synthetic gear lube
    By DN88Z in forum Drivetrain
    Last Post: 12-13-2005, 08:48 AM
