Results 1 to 19 of 19
    Member jbb6811's Avatar
    south carolina
    blue,blue
    00 z-28 m6, 06 H3
    6.0l escalade engine?????
    i have a freind with a 04(i think) escalade and he wants to part it out. so ... he said he'll trade me for my engine and $500 for the 6.0l. what do you guys think? yeah or nay?? i need to make up my mind before i order the new h/c package.
    my engine pretty well stock 50k miles
    his is stock w/ around 68k miles
    LS7 clutch,01 slave,Corsa 3" stainless exhuast,drilled/slotted rotors + ceramic pads,160 thermo,Mti clear lid,msd 8.5 wires & Ngk plugs...more to come!
    www.cardomain.com/ride/2311455
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    dont do it, its basically the same thing as your ls1 but its not built with performance in mind, i'm not sure if its all aluminum either, plus you wont feel any more power than the ls1 most likely
    Avoid that deal. The weight of the iron block would negate the minor power gains.
    That block is a good thing though being iron. At least if you start looking to push 800 RWHP.
    Dec 2004
    SS: NBM, tan top
    ^^^^ you wish lmao...
    south carolina
    blue,blue
    00 z-28 m6, 06 H3
    it is the iron block. i'm only looking to have around 400-450 to the tires(daily driver). i might buy it for a spare or my other project ( my s-10 ). thanks guys i'll just order the heads for my motor then.
    Member RJWZ28's Avatar
    Sunniest city on Earth
    2011 Silverado CC 4x4 6.2
    Only do it if you are building a drag car where the extra weight up front won't hurt so much, the extra displacement and iron block make for more power capability. Car Craft got 480 hp out of the low-compression six-liter with just headers and the mild GMPP LS1 cam, and the Escalade came with the high compression LQ9. 500 hp sounds easy with bottom-barrel cam, headers, and ECU tune. Just depends on whether you mind the extra weight.
    south carolina
    blue,blue
    00 z-28 m6, 06 H3
    with a nice h/c and the and bolt-ons i should be able to do the same in my car(ls1) like i said i have a s-10 that i want to convert to a v8. i'm just not sure if i want to make the camaro or the s-10 my drag only car. i'm thinking i'll leave my car and build the s-10. thanks for the help.
    Bragg NC
    Met. Sunset Orange
    01 SS
    The iron block "lQ9" That came in the escalae isnt a bad motor but i would agree with above and throw it in your s10, the weight is about 90 pounds difference from a fully dressed ls1. It does have the aluminum heads but it is limited to low to mid range power, its not a high rever like the ls1. From the factory they are rated at about 345 hp and 380 ft pounds. For 500 bucks its not a bad deal.
    Just my 02
    J
    You misunderstand slightly. The deal was $500 plus trade the LS1 he already has in his car. Not nearly so good a deal as $500 straight up.
    south carolina
    blue,blue
    00 z-28 m6, 06 H3
    your right $500 would be nice but he said he'd take $2000 for the motor(hareness & ecu) only
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    It would be a good motor to supercharge, if you have that in mind do the trade, I believe their are aftermarket companies that have root blowers for that engine, you will have lower compression heads with the 6ltr just right for supercharging. You will need his computor to go along with the engine.
    SteveC
    Quote Originally Posted by SteveC View Post
    SteveC
    I have an LQ9 block in my car. Stock computer.
    Roots charger will fit any LSx. LQ9/LS1/LS2/etc...
    Problem is hood clearance.
    LS1 > LQ9 in stock form.
    $2000 for that motor is a rip. Can get an LS1 for cheaper.
    Spend the coin on upgrades for the engine you already have. You could sell your LS1 block for more than it cost to buy an LQ9 block.
    south carolina
    blue,blue
    00 z-28 m6, 06 H3
    yes the intake on it (6.0l) is a monster
    Quote Originally Posted by jbb6811 View Post
    And if I am not mistaken, won't fit under the hood of an f-body.
    south carolina
    blue,blue
    00 z-28 m6, 06 H3
    yes i think your right thats why most go with the L76 intake.
    mr. luos whats you setup and hp.tq?
    LQ9 block. No bore, wanted to stay square (And save the $300 at the time).
    402 cubes. 11:1.
    See sig.
    Lowered, HID's, tinted.
    What heads are you running? Which intake manifold? Porting??? We need more info...
    http://www.ls1.com/forums/showthread.php?t=49109
    FAST should be getting ported this winter. Looking for roughly 550RWHP and 505 ft/pounds.
  1. Silverado Z71 on Escalade 22
    By Cutlass in forum GM Trucks
    Last Post: 10-20-2011, 06:38 PM
  2. In the market for an SUV.....would you buy this Escalade??
    Last Post: 04-18-2011, 08:20 PM
  3. '07 Escalade 6.0 Strength
    By 66MONEY-PIT in forum Internal Engine
    Last Post: 06-06-2008, 09:16 PM
  4. 99 escalade..only 72k miles, $11k
    By DADillac in forum Vehicles For Sale / Trade
    Last Post: 05-02-2008, 08:03 AM
