Results 1 to 11 of 11
08-08-2007, 01:39 PM #1Senior Member
- May 2007
- Bartlesville, Oklahoma, United
Bright Rally Red- 2000 Camaro SS #5075 M6
Can someone tell me the difference?
Between these types of spark plug wires from MSD. I want to change my wires, but cant decide between these. They both say that they fit my make and model, but ones $40 more. Im thinking its the distributor terminal ends. One says female/socket and the other says coil pack. I know I have coil packs, but they both say they fit my car??? Any help would be appreciated. Thanks
http://store.summitracing.com/compar...140+400122+115
08-09-2007, 11:50 AM #2Senior Member
- May 2007
bump
08-09-2007, 11:58 AM #3
08-09-2007, 12:05 PM #4Senior Member
- May 2007
http://store.summitracing.com/compar...4294908395+115
That should work
08-09-2007, 12:11 PM #5
Still doesn't work.
These are the ones I have on my Car. http://store.summitracing.com/partde...5&autoview=sku
These should be all you need
08-09-2007, 12:18 PM #6Senior Member
- May 2007
Yeah it was between that one and the MSD-32079. If you put that in the search on summit it should come up.
08-09-2007, 12:26 PM #7
I'm not 100% sure (might be the way they connect via coil). But the link I stated above are the ones you want. I would never spend $100 on wires.
08-09-2007, 12:28 PM #8Senior Member
- May 2007
Alright ill prob just get the $60 ones, thanks for the help.
08-09-2007, 12:31 PM #9
Not a problem. What plugs do you use?
08-09-2007, 12:32 PM #10Senior Member
- May 2007
Ill ive heard about is the NGK TR55. Would those be a good choice?
08-09-2007, 02:09 PM #11
Those are the plugs I use. There cheap and reliable
Difference between Z28 And SS?
By EnjoiJoe in forum Camaro / SSReplies: 44Last Post: 07-13-2008, 10:11 PM -
Difference
By spyke99 in forum Camaro / SSReplies: 6Last Post: 07-11-2007, 08:01 PM -
how much difference?
By bluefields88 in forum Suspension and HandlingReplies: 4Last Post: 06-12-2007, 04:44 AM -
Difference???
By DW2000TA in forum General HelpReplies: 3Last Post: 06-08-2007, 07:36 AM
