Results 1 to 2 of 2
    Junior Member Eddie 70's Avatar
    Kingston, Tn
    1970 Convertible Corvette
    Head Swap-Gasket ????
    I am getting ready to swap an LS1 into my 70 as you may have read already in the other thread. I have an 02 LS1 with 22k miles ready for the swap. I have since bought me a set of LS6 heads to go on this motor. When I do the head swap, I am curious as to what head gaskets would be the choice way to go. I would not mind a small bump in compression as it would only serve to help. But, If by going to a thinner gasket it is going to start causing PTV issues I hope not to get to that point.
    What is the stock thickness of Head Gasket? I know GM offers some MLS gaskets. Would it be worth my time to invest in these gaskets? I don't want to add more maintenance to the routine if I can help it.
    Any help is greatly appreciated.
    Thanks,
    Eddie
    Run what you brung
    Leesburg va
    2002 Transam
    Go with the Stock GM MLS gasket. Cant go wrong.
  1. Best place to buy LS1 Head/ Cam Swap Gasket Kit
    By BrownsMillsAntz in forum Internal Engine
    Last Post: 04-17-2012, 10:04 AM
  2. Head gasket help...
    By DIDZ in forum External Engine
    Last Post: 10-07-2010, 03:14 AM
  3. STS blown head gasket?? What head gasket
    By 2000sts in forum Forced Induction
    Last Post: 08-26-2009, 02:23 PM
  4. LT1 head gasket need help
    By morton in forum LT1
    Last Post: 01-12-2008, 10:07 AM
  5. Replies: 4
    Last Post: 11-13-2007, 08:58 PM
