Results 1 to 2 of 2
    Member silverz28camaro's Avatar
    Washington MO
    sebring silver
    2000 z28
    compression ratio question
    my 1978 440 engine has a 8.2 comp. ratio, now i have a great way to raise this with just a head swap going from 88cc chamber to a 78cc, also im going from cast iron to aluminum and ofcourse more flow, i know i cant ask for great mileage from this motor but if i get more compression won't it allow for more power without using more fuel and be able to use less throttle just cruising around
    this 440 is in my 88 ram pickup, probably gets 7-9mpg and will never get good mileage, but if i go with this head swap i will see more power, less weight and if there is a mpg increase its a bonus, what do you all think
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    yes, it could.
  1. Compression Ratio
    By Bouvers in forum Internal Engine
    Last Post: 01-12-2009, 01:56 PM
  2. Compression ratio for Supercharged LS1?
    By JeremyRay in forum Forced Induction
    Last Post: 06-19-2007, 03:02 PM
  3. compression ratio?
    By wesTXwitesnake05 in forum Internal Engine
    Last Post: 07-09-2006, 10:29 AM
  4. compression ratio ?'s
    By cannotbeheldliable in forum Forced Induction
    Last Post: 04-13-2006, 10:26 AM
  5. What Compression Ratio
    By JD_Z28 in forum Forced Induction
    Last Post: 03-18-2006, 04:11 PM
