    Member Whiteboycntdnce's Avatar
    Virginia
    2000 / SS
    Fly by Wire Switch
    What exactly does fly by wire mean? I can't use to the normal rpm window switch nos offers, it says it wont work on the DIS ignition system, but I saw a new part number that says it will work w/ our ignitions and cheaper actually..... But I dont know what "Fly by Wire" means. Thanks
    Member jperkins812's Avatar
    Tennessee
    Fly by wire means you do not have thottle cables. It is the system that alot of newer motorcycles use, and it gives better thottle response. It is controlled by an electrical wires and sensors.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    it's also on the corvettes and LS2 gto cars.
    d
    2002 z28
    it turns on at a certain voltage instead of being activated from a wot switch. and it can be used on the ls1 s
  1. Help: coil wire for rpm switch?
    By youngbird in forum Nitrous
    Last Post: 03-20-2013, 06:55 PM
  2. Question: How to wire in a lock up switch?
    By allbaugh_04 in forum Automatic Transmission
    Last Post: 05-18-2010, 04:18 PM
  3. wire from stop lamp switch to turn/hazard switch?
    By swisscheese in forum Stereo and Electronics
    Last Post: 08-11-2008, 11:22 PM
  4. FS: Nitrous Outlet switch panel & WOT switch
    By MagicMan in forum Parts For Sale / Trade
    Last Post: 11-28-2006, 08:12 AM
  5. RPM window switch, and WOT switch
    By corvettelover in forum Parts Wanted / Trade
    Last Post: 12-02-2005, 12:21 AM
