    Senior Member GottaHaveLS1's Avatar
    Connecticut
    1999 Trans Am M6
    Lift motor for header install??
    I was going to have my friends dad install my headers for me. but he says he can't do it in his driveway because you have to lift the motor on one side. I've heard that this isn't always necessary for the latest pacesetter LT's.
    I know I'll have to pay more at the shop but some have offered $300 and thats not a bad deal. What have you guys done for LT installs?
    member HASTINGSRJ's Avatar
    Jan 2001
    Franklin, Mass
    00 SS Vert#0540/ 14 GMC
    you shouldnt have to lift the motor, even if you do, its not a big deal. You just have to make sure you get the car high enough to get the Lt in there from underneath.
    Black 00 SS M6, vert, #0540 408ci
    DD 2014 Sierra All Terrain
    Senior Member 35thAnniZ28's Avatar
    eating bulldog
    son of biscuit
    you don't need to raise the engine...just take off the exhuast manifolds..and wiggle em in there..it took me n my friends 2 days to install them..
    Indianapolis, IN
    All Black
    83, 87, 02 All WS6 T/As
    Done it a few times now.. like above.. get it high enough, and you can wiggle them in.. PS fit REALLY well! Save the $300 for other mods. Good luck!
    -Geno
    1983 Black WS6 "WindCharger"
    1987 Black WS6 "WS87"
    Sold the other four f-bodies
    Connecticut
    1999 Trans Am M6
    that's what I thought. My friends dad must have just heard that from someone... or he doesn't want to do it.
    Indianapolis, IN
    All Black
    Maybe on certain cars you have to.. and then again, it MIGHT maker it EASIER, not faster.. but MAYBE easier... With a set of gear wrenches, some pb blaster/wd40, a couple extensions with a wobble, and a universal joint, its not hard at all. Just expect to donate a little bit of blood to your car. Good time to replace your plugs and wires too.
    [QUOTE=GottaHaveLS1;913010]that's what I thought. My friends dad must have just heard that from someone... or he doesn't want to do it.[/QUOTE]
    that would be my first guess. It's not a job most really look forward to. I had to trim the casting plug a little on the drivers side of the block to get mine in. Not a hard job, just time consuming and I'm guessing he really doesn't want to spend a weekend under your car. Tackle it yourself. Use the write ups and follow them to the letter and you'll be fine. Hand tools are all that you need. The only tricky part is getting the car up that high on stands. I really didn't like that part at all but once you have the headers in place in the engine bay you can let the car back down to a safer level to finish the install.
    Driving like i stole it!! dafizzman1's Avatar
    Centereach, NY
    1998 Formula
    mine is a 98. (dont know if it matters) p/s slid right in. d/s motor mount on the motor side needed to be un bolted and raise about 2 inches. wanst bad though. just a killer on the neck and back.......laying on the floor and all..
    If you have the means and the desire, be prepared to do whatever it takes.
    so far:
    suncoast creations functional ram air setup,pacesetter LT's/ORY,magnaflow,pro 5.0,hurst stick,LS6 cam,4:10 gears/stock rear(screaming for mercy!!!)
    -still more to come!!!!!!
  1. SFC install...4 post lift
    By molecularmann in forum General Help
    Last Post: 10-22-2010, 01:35 PM
  2. do i have to lift the motor for header install?
    By greatwhiteZ28 in forum External Engine
    Last Post: 03-21-2007, 03:23 PM
  3. How to drop motor from bottom with a lift?
    By mikeaford in forum Internal Engine
    Last Post: 02-19-2007, 12:08 PM
  4. Header Install Question - Motor Oil Dip Stick
    By MISSMYZ in forum External Engine
    Last Post: 02-15-2007, 06:14 PM
  5. Pull the motor without lift?
    By AirMarcus in forum General Help
    Last Post: 01-19-2007, 07:03 PM
