Results 1 to 3 of 3
Thread: shift problems
    around
    shift problems
    i have a 94 z28 a4 it seems like when i push down hard on it, it gets to like 4 grand and seems like it would keep going until 5 so i let off a little and it shifts hard it also shifts out of first really hard is my tranny going bad?
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    sounds fine the transmission will hold the shifts when you are giving it generous pedal and bumps the pressure so it will shift higher and harder when you mash it then when not. It should hold it until close to redline if you have it to the floor. Also doing this but letting out before it shifts the pressure is already boosted so it will shift firmer even if you let out right before the shift.
    around
    thanks i was making sure it wasnt problem because the guy i bought the car from said it had a newer tranny with less than 7k miles on it and when i mash it it hits the redline then shifts idk if thats bad or because it might not be same as stock
  1. Transmission shift problems
    By trader0397 in forum Computer & Tuning
    Last Post: 04-01-2013, 06:56 PM
  2. HARD SHIFT problems!!
    By airmaxon1 in forum Automatic Transmission
    Last Post: 09-14-2007, 06:57 PM
  3. Shift Problems
    By miller456 in forum Manual Transmission
    Last Post: 03-17-2007, 04:09 PM
  4. shift light problems
    By 2000PewterTA in forum General Help
    Last Post: 07-30-2006, 08:13 AM
