Thread: Robbed
08-02-2007, 12:48 PM #1
Robbed
I just had to ask -- to see if it was just my car, or what, but it seems like the heat robs LT1's more than any other motor. I mean, I owned an '98 LS1, and that car even in the middle of the summer, did not let the heat get to it. I mean of course it was it's fastest in cool weather, but it just seems like with the LT motors 95-degree heat can rob of you of 30 to 40 horsepower easily, atleast that's what it feels like. Is it the opti-spark that's very prone to heat, and maybe that's what takes the power away momentarily? I'm serious guys, my car will melt the tires viciously at night (off the bottle) with no problem, and then when it's 90 -deg or above it's like it doesn't even want to spin. I just want to know if someone can tell me exactly what makes this problem stand out so much on LT1's??
486/438
10.68/127 N/A
08-02-2007, 01:50 PM #2Member
- Jul 2006
- oceanside ca
Red- 06 GTO
dang 30-40hp, not that much maybe like 3-5 but nothing to noticable.
08-02-2007, 02:16 PM #3
After tuning my PCM, I was seeing less than 10hp loss between 170-200 degrees. Mine rarely gets above 185~ anyway
08-02-2007, 06:10 PM #4
08-05-2007, 08:06 AM #5Member
- Jun 2007
- NC
green- 94 z28
I don't notice THAT much of a difference with my LT1 in even 100-105 degree weather. Maybe you're just so frustrated that it makex you feel like it's even more.
I am, however, working on a custom fiberglass hood for my Lt1 and planning that will be an exact replca of the current hood but I'm going to actually cut out the 2 vents hoping it will help some. Just gotta read more in my autobody book on how to get it bolted in good enough so that it doesn't rattle at high speeds.
Is there any paint that I could use that would block some heat? I'll have to search for that later today when I get back home.
08-05-2007, 08:54 AM #6
08-09-2007, 04:25 AM #7Member
- Buffalo
Fortunately, my car does not do that. It's strong 24x7. But I would check any electronic device that checks for air temperature or humidity or even a map sensor. Sometimes the computer may not see a faulty sensor but the sensor will still give false information. I'd check resistance values or replace sensors related to climate conditions. It would be interesting to monitor your timing when you think the engine is not running at optimum. It strongly doubt it's an optispark, that would cause a misfire. You have an over all tuning problem and it's not going to be a bad wire or something like that or "mechainical". I would check anything that effects the timing of your car. And a computer takes various real time measurements to adjust the timing on the fly. You'd have to do some research on that. Its too early for me. =)
08-09-2007, 09:26 AM #8Junior Member
- Feb 2007
- Atlanta
black- 94 z28
man i live in stockbridge GA and it is like in the 100's i got a 94 z mine is doing the same shit i dont have a solution yet but i am just lettin you noe ure not the only one
08-10-2007, 11:13 AM #9Junior Member
- Sep 2005
- Irvine, CA
Black- 1994 Camaro Z28
Do you have a data logger? Maybe the car is retarding the timing because of the heat and other stuff. Log your car during the heat and see what happens.
Jody J.
08-10-2007, 05:30 PM #10
08-12-2007, 10:49 PM #11Member
- Buffalo
also, after you get the mis fixed, the knock sensor can also effect the timing. MIght consider getting a lt4 knock module. I have one on my car.
08-13-2007, 10:16 PM #12
F my life!!!! I was robbed
By tatertot91 in forum Almost Anything GoesReplies: 96Last Post: 10-05-2010, 07:00 AM -
Just robbed this dudes house
By 86 IROC-Z in forum Almost Anything GoesReplies: 20Last Post: 10-02-2010, 01:30 AM -
Galarraga ROBBED of a perfect game!!! ROBBED!!!
By Hi-Po in forum Almost Anything GoesReplies: 44Last Post: 06-05-2010, 08:15 PM -
Losers robbed by cripple...
By 1MileCrash in forum Almost Anything GoesReplies: 3Last Post: 04-05-2008, 08:01 AM -
Am I Getting Robbed at the NOS Fill Station?
By MISSMYZ in forum NitrousReplies: 17Last Post: 09-24-2005, 09:39 AM
. None of my other cars suffered from heat as bad as this one. It could be a number of things, who knows???
