Results 1 to 14 of 14
    Feb 2007
    austin
    Black/Black
    '00 Firebird WS6 T/A
    performance mode?
    hey, how do you put the car from "normal" to "peformance" mode?
    in hptuners, there are different shift points for normal and performance, and some other things seem to be alterable by this as well. anybody use this or have any experience with it?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    those are tables for those vehicles equipped with the performance mode button.
    Feb 2007
    austin
    Black/Black
    awww... i want it!
    in all seriousness, this was an actual option? my v6 had the performance mode tables too.
    orlando, fl
    2014 camaro 2ss/rs
    yes, my 94 formula had the button. some get the second gear start button. if you notice, you have tables for both auto and manual trans.
    Feb 2007
    austin
    Black/Black
    how would one go about adding the button? it would be pretty handy as far as nitrous use shift point reduction or just if you want to keep it tame most of the time...
    orlando, fl
    2014 camaro 2ss/rs
    have to get the wiring diagrams to wire it to the PCM.
    Junior Member sreve's Avatar
    St. Louis Area
    '02 B4C Camaro
    this is something i have done some research on and definatly want to do.
    performance mode tables are used on pick ups for tow haul mode. the bcm enables it
    via class 2 serial data to the pcm. add a wire to the bcm to a monentary switch from a late model G van (tow-haul switch is on the dash) and your in.
    BUT!! you have to program the bcm to enable these tables.
    i saw something a while back about a guy that was doing something with the bcm for a shift light on GTO m6 cars. like a dumb ass i did not subscribe to the thread. do not even remember the forum, as i belong to many. he was in the north east PENN. i think.
    find the way to program the bcm i'll post up the pin outs
    Feb 2007
    austin
    Black/Black
    found it. Copy & Paste.
    http://www.hptuners.com/forum/showthread.php?t=8887
    also, I cannot for the life of me find the dam connector they r talking about. would there be any reason for its absence on a 2000 T/A WS-6?
    Member jag42420's Avatar
    Aug 2006
    Kentucky
    2002 WS6 Trans Am
    I thought the pcm switched from normal to performance tables at a certain throttle? Wow. If you could use a switch to switch tables, you could tune normal for mileage and efficiency and performance for power. Like Superman and Clark Kent
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by richard head View Post
    it's just how the car was ordered from the factory.
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by jag42420 View Post
    there are normal, cruise, and WOT tables for shifting. then there's the performance tables.
    Aug 2006
    Kentucky
    2002 WS6 Trans Am
    I still the tuning newbie...learning more everyday...
    Feb 2007
    austin
    Black/Black
    I solved the problem. High pressure over about 280 ft-lbs, 2/3 over 320 and full pressure over 340. Shifts hard as hell at WOT and soft as hell at idle/lo throttle openings.
    orlando, fl
    2014 camaro 2ss/rs
    there you go
  1. performance mode/torque converter
    By MotorDogStar in forum Firebird / WS6
    Last Post: 06-09-2009, 09:14 PM
  2. Performance mode switch
    By jag42420 in forum Computer & Tuning
    Last Post: 12-21-2007, 07:31 AM
  3. performance mode switch?
    By NE98LS1 in forum Automatic Transmission
    Last Post: 09-10-2006, 08:19 PM
