    Member RS_SS69's Avatar
    Denver
    Onyx Black
    2001 SS
    Cam guru's come in please
    Over the winter im going to do a cam, I want great overall power and torque I will be using stock heads, pacesetter LT's, ORY, TSP Rumbler, lid, ported TB, 3.73 or 4.10 gears and a 150 wet shot here is the cam I was thinking about
    Texas Speed 228R Camshaft
    LS6 oil pump
    Comp 918s
    LS2 timing chain
    Cam gasket kit
    Is there anything im missing here? Also are there any other cams you guys would recommend, I dont want to flycut at all, I want a good power band not peak power and a nice lope, let me know what you guys think thanks. Car is an 01 SS M6
    STAY PUFT thecorrectformula's Avatar
    Delaware, OH
    Make sure you get it tuned as well once your done installing. Can't stress it enough for additional power.
    Denver
    Onyx Black
    2001 SS
    Quote Originally Posted by thecorrectformula View Post
    Friend will tune on dyno with HP tuners
    I'm running that same cam with 5.3L stage 2.5 heads. I've been pretty happy with it. Makes good power. I'm still in the process of tuning it but it's pretty close right now. I got mine on a 114 LSA a 112 would lope harder. Here's a short vid of mine through the exhaust and then with the cutout open.
    Denver
    Onyx Black
    2001 SS
    Orion thanks for the video!
    Senior Member Wheeler99WS6's Avatar
    indiana
    black, 05 Roush
    black, 99 T/A WS.6
    Quote Originally Posted by RS_SS69 View Post
    LS6 oil pump
    Comp 918s
    LS2 timing chain
    Cam gasket kit
    Dont forget the hardened pushrods.......that is the cam I plan on going with.
    1999 T/A WS6 Black -------SOLD
    05 mustang Roush sport;
    DOB manifold, m122 SC, 47lb injectors, gt500 TB, roush TVS CAI, Detroit rocker SC grind camshafts, Mac LTs, off road x, roush off road mufflers, roush short throw shifter, kenne bell BAP, Brenspeed 93 octane tune. 479rwhp 436ftlbs SAE.
    Junior Member edcmat-l1's Avatar
    Jun 2006
    Virginia Beach, Va
    Dont know if dual springs will fit without machine work, but if they do, use them.
    Avoid single springs if at all possible. Never liked em, wont use em, try to talk people out of using em, and now comp is recalling a shit load of them.
    They are a disaster waiting to happen. A flawed design from the word go. If a single spring breaks, chances are it will take out your whole motor. If a dual breaks, you still have a second spring that will at least save your motor.
    They have had catastrophic failures in alot of engines.
    i got the prc dual springs with my 5.3 stage 2.5's. technically more spring than I need but I like them for the exact reason you mention
    Senior Member Street Lethal's Avatar
    New Jersey
    Over the winter im going to do a cam, I want great overall power and torque I will be using stock heads, pacesetter LT's, ORY, TSP Rumbler, lid, ported TB, 3.73 or 4.10 gears and a 150 wet shot here is the cam I was thinking about...
    I wouldn't bother with the 228R if you do not plan on any cylinder head work being done. Yes, you can get the engine w/228R running superbly with custom tuning, but to maximize the 228R, you need better DCR/SCR, and to maximize power with the stock cylinder heads, you need a cam custom tailored for them....
  1. Any 4.3 guru's here?
    Last Post: 09-02-2013, 10:42 AM
  2. suspension guru ?
    By Orange SS in forum Suspension and Handling
    Last Post: 11-28-2006, 06:18 PM
