Results 1 to 20 of 20
    Junior Member sweet2000's Avatar
    Kentucky
    pewter
    2000 camaro ss
    gto ls6 intake and throttle body
    I have a chance to buy a ls6 intake and throttle body off of a 2004 gto. My question is will i have to change the maf to run the intake and throttle body.
    Thanks for any input
    LoudMouth SStriker's Avatar
    Westminster/Sykesville, Maryland
    2000 Trans Am
    Just get the Intake, and use your stock TB. You can port and polish it and it will work great.
    No the MAF will work fine.
    Feb 2006
    MD
    Pass on the throttle body, it won't even work on your car.
    loyall ky
    black, and black
    04 M6
    throttle body
    im just curious why and ls1/ls6 throttle body from a gto wont work on a ls1?? please enlighten me
    Member SScott's Avatar
    Fairfield
    02 SS #8719
    Because GTO is drive by wire, f-body cable.
    loyall ky
    black, and black
    04 M6
    throttle body
    um you two are wrong go look at a 04 ls1 gto, and tell me i am wrong the 04 ls1 gtos have a ls6 intake and the throttle body is drive by cable as u say , 05/06 ls2 gtos are by wire, before you comment on something know what you are talking about,
    loyall ky
    black, and black
    04 M6
    tb
    this is what i just took on my gto 2 days ago
    Retired Outlaw Sum Bitch
    04 GTO has a throttle cable...05 and 06 are drive by wire..............
    Quote Originally Posted by sweet2000 View Post
    You should be good to go....The only thing I cannot remember is the PCV setup.....I cant remember if the valley tray is different.....fuck it...go for it I think it is a swappable thing man.....
    2000 Trans Am
    Quote Originally Posted by kyemt View Post
    Yeah but there is no need to get the New TB its probly the same one that his car came with stock.. Save the cash and port your Tb.
    Feb 2006
    MD
    I got the years mixed up. His being a 2000 will work with the 2004 GTO throttle body. The 98-99 cars will not work.
    Kentucky
    pewter
    2000 camaro ss
    Thanks for the info
    Member jeremy_m70's Avatar
    ALABAMA
    SILVER
    1998 Z28
    Quote Originally Posted by Marc 85Z28 View Post
    Wouldn't the 98-99 cars work with egr gone???
    Feb 2006
    MD
    Quote Originally Posted by jeremy_m70 View Post
    Throttle body cams are different. Just bolting one up will leave the throttle partially open.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    yes, you can remove the EGR on 98-00 cars and they will still run.
    orlando, fl
    2014 camaro 2ss/rs
    yes, the GTO have the LS6 valley cover. doesn't matter, the PCV still hooks to the neck of the intake in the same place. what does matter is the coolant lines. the LS1 have coolant lines running under the intake. with the LS6 they use blockoffs for the rear coolant holes and only have a crossover line in the front.
    you can see it here in this pic
    http://store.summitracing.com/largei...le-30039_w.jpg
    it's not needed. you just need to remove the ribs off the bottom of the intake to clear the LS1 lines.
    Its a 4 door vette bitch! JOHN_DEERE_LS6's Avatar
    Laingsburg, Michigan
    Black Raven/Ebony cowskin
    2005 Cadillac CTS-V
    hate to thread jack but what exactly do i have to modify/change/use for parts to put a ls6 on my 99 t/a.. i thougth i remember reading someplace you have to block somethign off, or a sensor, or do something other than just bolt the bitch on.... thanks
    anyone have the part number for the ls6 intake that would go on my car the easiest if there are any difference in ls6 intakes?? best place to buy one from... cheapest place to get one?? anyone have one?!?!?! lmao
    thanks again
    Feb 2006
    MD
    The only you need to change it the EGR setup. Other than the SLP LS6 intake (which is modified to accept EGR), the LS6 intake has no provisions for the EGR. The manifold is literally a direct swap, and an easy one at that. You will need to remove the EGR and install block off plates on the exhaust manifolds/headers. Buy the coolant crossovers designed for the LS6 manifold - don't crush/bend the stockers and grind on the intake.
    2005 Cadillac CTS-V
    thank uuuuuuuuuuuuuuuuuuuu!! so a slp intake my best bet?? or are there outragously priced like the headers and full slp exhaust i have lmao....
    Feb 2006
    MD
    Quote Originally Posted by John_Deere_LS1 View Post
    Yeah, the SLP modified LS6 intakes are quite expensive, like $200-$250 more than a used LS6 intake. Used SLPs are VERY rare.
  1. Ls1 Intake & Throttle Body
    By SMWS6TA in forum Parts For Sale / Trade
    Last Post: 09-13-2011, 08:15 PM
  2. Intake and throttle body...
    By pewterzron in forum External Engine
    Last Post: 11-16-2008, 02:01 PM
  3. throttle body and intake ??
    By red-bandit in forum External Engine
    Last Post: 09-01-2007, 01:55 AM
  4. Intake and Throttle Body Recommendation
    By mpramsey in forum Internal Engine
    Last Post: 01-20-2007, 09:39 AM
  5. WTB: ls2 intake manifold & throttle body.
    By cbrf4i1 in forum Parts Wanted / Trade
    Last Post: 12-11-2006, 09:52 PM
