07-28-2007, 04:26 PM #1
- Nov 2005
- Huntsville AL
Bright Green Metallic- 1998 Z28 Camaro
Dropped Socket in Bell Housing!! Can I drive?
Was unsuccessfully bleeding my clutch hydaulics and dropped a socket in the bell housing. Is it going to jam between the flywheel and the housing? I may need to go in to replace the slave anyway, but I'd like to drive it to a shop. Tow?
Jim 98 Z28 BGM
07-28-2007, 04:30 PM #2
That sucks. Did you try using a flexible magnet or something to try to fish it out? I don't really know...but I personally wouldn't drive it until I got it out of there.
07-28-2007, 04:58 PM #3
- Nov 2005
- Huntsville AL
I've got a powerful small magnet, I'll give it a shot. Something tells me it will slide up against a casting seam or some such that will stop it.
Jim 98 Z28 BGM
07-28-2007, 05:01 PM #4
One other idea......I've never really looked at the bellhousing to see what it looks like, so I'm not sure if this would work or not. What if you got a really big, REALLY strong magnet from somewhere and moved it around on the outside of the bellhousing, and then up to the top of the bellhousing so it would drag the socket up the side of the inside of the bellhousing to where you could grab it???
08-07-2007, 07:49 PM #5
- May 2007
- Fredericksburg, VA
Black- 2001 T/A M6
Or just take the bellhousing off, that will require some work though
08-08-2007, 08:02 AM #6
yea it will require some work allright.......that sucks man.
T-56/LS1 Bell housing
By AaBryan in forum Parts Wanted / TradeReplies: 0Last Post: 08-18-2008, 04:48 AM -
WTB: T-56 Bell housing for LS1
By tilly in forum Parts Wanted / TradeReplies: 2Last Post: 12-21-2007, 05:00 PM -
Dropped Socket in Bell Housing!! Can I Drive?
By eldrijt in forum General HelpReplies: 11Last Post: 08-05-2007, 08:03 PM -
Bell Housing for 01-02 T56
By JD_Z28 in forum Parts Wanted / TradeReplies: 1Last Post: 07-19-2006, 07:46 PM -
Bell housing for T-56
By JD_Z28 in forum Parts Wanted / TradeReplies: 0Last Post: 03-14-2006, 03:23 PM
