Thread: patriot heads
07-27-2007, 12:52 PM #1
patriot heads
Hi everyone, i dont really know too much about h/c. But i was lookin into gettin some patriot stage 2 heads along with a 224/224 .581/.581@112lsa. Does anyone have any opinions on this set up? Or does anyone have any other suggestions? I pretty much have all the bolt ons. Any opinions will definately be appreciated. THanks
07-27-2007, 01:58 PM #2Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Work with Gunner at Patriot...guy will work with you to get the ride/power/performance you want. He knows his stuff front to back....top quality products/service from Patriot.....lot of people make heads/cams....but Gunner is top of the heap for supporting folks running his set ups.....
This is my signature. It is mine. Nobody else has one like it.
07-27-2007, 02:33 PM #3
i have that exact setup currently on my car. Comp Cams 224/224 .581/.581@ 112lsa, and Patriot Stage II Ls6 "Style" heads (2.02"int/1.57"ext at59cc). I have all supporting cam mods LT's/ORY, Ls6 intake, SLP Lid and SLP LM cat-back, you will be over 400rwhp running that setup. the numbers im putting down are in my sig. When I installed the heads back in Jan '07 I gained 36rwhp/24rwtq...
if you have any questions, feel free to ask them. as Sarge said, call and talk to Gunnar. I did numerous times before finally getting them. I believe you would be happy with that H/C combo. if you wanted to, as a suggestion you could even setup to a bigger cam like a 228/228. i only say this because i have a TSP 231/237 5.98/.595 @112+2 lsa I plan to put in in the future...
also check out the videos in my sig as well...2018 CTS-V: °°668rwhp/658rwtq°°
2013 ZL1: °°590rwhp/576rwtq°°
07-27-2007, 11:06 PM #4
tried and true combo you have there. Very popular. Should make good power and still be very streetable. Moving to the internal section for you.
07-28-2007, 09:31 PM #5
Whats the number to gunner?
07-29-2007, 04:33 AM #6
Question: Patriot Heads
By Bama99z in forum Internal EngineReplies: 13Last Post: 09-16-2009, 08:08 AM -
Patriot heads question
By shaggsm3ls1 in forum Internal EngineReplies: 3Last Post: 09-16-2009, 07:51 AM -
patriot heads pakage
By Pony_Eater in forum Internal EngineReplies: 5Last Post: 02-04-2009, 04:10 AM -
AFR heads vs Patriot Heads.. CNC ported
By WARP211 in forum Camaro / SSReplies: 6Last Post: 03-01-2007, 08:51 AM -
patriot LQ9 6.0 heads???
By ls1matt in forum Internal EngineReplies: 3Last Post: 04-12-2006, 04:43 PM
