Results 1 to 3 of 3
07-25-2007, 05:54 PM #1Junior Member
- ohio
red- 1998 camaro z28
Torque-Arm 2 Rearend coverd in Diff.fluid
Torque-Arm 2 Rearend coverd in Diff.fluid? but when I look, it is full.
07-26-2007, 12:32 AM #2
probably past owner..i do also... clean it with brake cleaner..just because
07-26-2007, 12:40 AM #3
A lot of folks have problems with the pinion seal "weeping". It only takes a few drops to sling onto the TQ arm. Clean the area and check again after some driving. The pinion seal is easy to replace but honestly more people have had problems after because the it requires a new crush collar and re-torqueing the pinion bearing and very few take the time to do it right.
Diff Fluid
By Sarge in forum GTOReplies: 42Last Post: 06-10-2011, 08:38 PM -
Changing diff fluid..
By ls1fan74 in forum GTOReplies: 37Last Post: 09-03-2009, 09:10 AM -
Best Oil, Filter, and Diff Fluid
By Intrepidman in forum General HelpReplies: 28Last Post: 10-08-2008, 11:02 AM -
diff. fluid/ additive
By imflyn in forum DrivetrainReplies: 5Last Post: 11-02-2006, 10:54 AM -
best diff fluid? good diff cover?
By ErikElvis in forum Camaro / SSReplies: 3Last Post: 03-23-2006, 08:49 PM
