    Kansas
    Bright Red
    '99 T/A
    low pitch whine, on low speed cornering????
    My 99 TA has a low pitch whine when I turn a normal street corner but goes away as soon as I straighten and start to accelerate an idea what that is?
    Member Flobeast385's Avatar
    NC
    1999 TA M6
    Could be a front wheel bearing since you hear it more in a corner, if you notice it setting still it could also be something as simple as low power steering fluid. You could also try rotating your tires, I diagnose cars everyday and its really hard to unless I am driving the vehicle. good luck though
    Missouri
    2000 Trans Am WS6
    rear end problems too :(
    My makes noise too but not only in corners. It seems like mine makes noise when it has been sitting for a while. Mine makes a clicking sound (kinda like a playing card on the spoke of a bicycle). Does it from 1-15 MPH, by then car is going to fast and sound is probably sounding like one BIG sound. Any ideas? I have a slow leak in the front of the third member and am getting ready to buy a kit and change the whole thing out. I currently have a 00' TA WS6 with about 90k on the ticker. Believe the rear end is 3.23's (someone correct me if I am wrong, or please tell me where to go to verify this.) I am wanting to go with 3.73's maybe 4.11's. Is it prolly a Torsen series 3 carrier? ANy help would be appreciated.
    BlackHawk T/A
    Guest
    RPO code:
    GU5: 3.23
    GU3: 2.73
    Missouri
    2000 Trans Am WS6
    thanks
    Quote Originally Posted by BlackHawk T/A
    RPO code:
    GU5: 3.23
    GU3: 2.73
    Thanks BLACKHAWK...Do you know anything about the carrier?
  1. Perfect Pitch, GWB Ceremonial Pitch 2001 World Series (vid)
    Last Post: 09-11-2015, 05:23 PM
  2. High speed cornering
    By bossho in forum Suspension and Handling
    Last Post: 11-09-2009, 04:21 PM
  3. whine noise that changes pitch with gear change
    By enthashyt in forum General Help
    Last Post: 09-04-2006, 11:17 PM
  4. Cornering G Forces...
    By Hot Black Trans-Am in forum Suspension and Handling
    Last Post: 06-03-2006, 01:36 AM
  5. Will 255's rub when cornering???
    By alamantia in forum Wheels and Tires
    Last Post: 04-01-2006, 04:52 PM
