    maryland
    98 camaro z28 m6
    something cuting in to my window...please helppp
    i realy need some help on this.
    when i put my window down once its in side the door the door panel pushes out like 1/2 inch and then goes back in when i put the window back up.
    now on the glass, on the inside it looks like over time something on the inside of the door has rubed in to the glass.
    i just got my windows tinted and the guy said that what ever rubed in the glass will do the same to the tint and rip it all up.
    i was wondering if any one has info on how to fix this
    Chicago burbs
    sebring silver
    98 camaro SS
    i have this same problem and it **** up my tint bad
    BlackHawk T/A
    Guest
    Could you open it up and check for rocks or something? Only way to find out...
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    it might be the clips to your door panel. There should be one screw in the map pocket, two in the handle, one on the plastic trim and one inside it. Lift the panel up carefully and see iff the clips clip back into the doorshell.
    Aug 2000
    Indy
    tAke off the door panel - real easy. There is an adjustable guide that keeps tension on the glass. Sounds like the soft cloth covering fell off or as with me it actually broke leaving metal on glass to guide the window. It's located up top away from the hinged side of the door. Find a link to replacing the window motor. There is a good one with all the places there are screws and how to disconect power window/lock plugs. There is no screw in the map pocket on the Z.
    Richmond, Va.
    all 3 of mine have the same problem
    maryland
    98 camaro z28 m6
    there are 2 metal tabs that push against the window, there is susposta be some type of felt, carpet on them that wore off there like 15 a pice
  1. helppp
    By mb z28 m6 in forum Camaro / SS
    Last Post: 05-23-2009, 01:58 AM
  2. Helppp!!!
    By camaro00ss in forum Camaro / SS
    Last Post: 04-26-2007, 01:02 PM
  3. True Dual Exhuast for 02 SS HELPPP!!
    By Camaro02SS in forum Camaro / SS
    Last Post: 06-26-2006, 05:57 AM
  4. Need Camber Helppp
    By Erik in forum Suspension and Handling
    Last Post: 11-24-2005, 01:49 AM
