Results 1 to 20 of 60
Thread: how to turn headlights off?
07-23-2007, 07:33 PM #1
sounds like a retarted question but is it possible to turn my headlights off at night? i know if i start the car with the e-brake up the lights will stay off
07-23-2007, 07:40 PM #2
- Nov 2006
- Broken Arrow, OK
Keep your ebrake up on the first notch. It keeps the headlights from coming on automatically. It doesn't engage the brakes either as long as you keep it on the first notch. The brake light will light up on the gauge cluster.
07-23-2007, 09:41 PM #3
wow i learned something now...would you know how to do that without the e-brake..like by passing the lil sensor on the dash
07-23-2007, 11:15 PM #4
thanks a ton
works perfectly
07-24-2007, 01:25 AM #5
- May 2007
- Seattle
Jetstream Blue Metallic- 2008 Z06 Corvette
I asked the same question a little while ago, I'v never tried this, hope it works. A guy on this board sent us all a detailed way to disable the sensor, complete with pics. I'm going to try to post it, if it doesn't work this time, I promise to get posted later. It IS what you're all looking for. It over-rides the factory sensor and gives you complete control to turn them on and off at will. I like to run the driving lights with the running lights due to my headlight covers. It's a cool effect. Again, if this doesn't work, be patient, I'll try again after work.
07-24-2007, 01:29 AM #6
- May 2007
- Seattle
What the heck, try this...http://members.cox.net/blownls1/drl/drl.html
07-24-2007, 02:38 AM #7
- Nov 2006
- Indianapolis
I F'ing HATE non-defeatable automatic headlights! Good luck.
07-24-2007, 09:53 AM #8
when i pull my e brake, they stay on.
07-24-2007, 09:59 AM #9
the car has to be off
07-24-2007, 10:27 AM #10
so i need to pull the brake while it is off and then start it?
07-24-2007, 10:37 AM #11
yep
07-24-2007, 11:17 AM #12
- May 2007
- Seattle
If you guys go to the link I posted it will show you how to disable the auto headlight function completely. Then you won't have to play with your parking brake, you can use it when the car is parked!
07-24-2007, 03:43 PM #13
07-25-2007, 10:06 AM #14
07-25-2007, 02:01 PM #15
tried it last night, worked perfectly. kinda fun to play with. none of the lights turn on until you push the handbrake down. me and my pals were having fun with it.
07-27-2007, 10:14 PM #16
Here is the method I am going to do next week http://www.xse.com/leres/ss/drl.html. Instead of just saudering in a wire, I am going to sauder a wire to each spot on the board, then wire in a switch. This way I can turn the DRL on if I ever have to. This way is very easy cause I've had the radio out and looked at the area where this needs to be done to. Goodluck, or the ebrake always works great!
07-27-2007, 10:21 PM #17
07-28-2007, 12:13 AM #18
Is this sensor only in Camaros? I've never seen it before.
07-28-2007, 07:00 AM #19
07-28-2007, 09:54 AM #20
1967 rs/ss camaro headlights won't turn on
By 1967ls2 in forum Camaro / SSReplies: 1Last Post: 01-28-2014, 07:42 AM -
05 vette headlights turn off while driving
By JR99RamAir in forum General HelpReplies: 1Last Post: 03-29-2011, 05:30 PM -
got the new grill and headlights/turn signals on..
By Poppn in forum Camaro / SSReplies: 13Last Post: 09-07-2009, 04:13 PM -
Question: Anyway to turn off automatic headlights?
By amon37 in forum Stereo and ElectronicsReplies: 12Last Post: 10-03-2008, 12:22 PM -
smoked headlights and turn signals
By slo98ss in forum Appearance SectionReplies: 9Last Post: 11-02-2005, 02:06 PM
