11-01-2005, 10:18 AM #1SpamcannonGuest
'01 T/A OBDII code reading help needed
My '01 T/A has a "Service Engine Soon" light on (although I think I found the issue - burnt taillight bulb). But, I bought an Actron CP9125 (most basic) scan tool - $20 at PartsAmerica.com. I connected it to the OBD port and the scanner never accepts that it's even plugged in to the car as per the manual. I checked the pins and all - all clean and straight. So my questions are:
1. Do you have to do anything special to the T/A (besides turning the ignition to "Run") to activate the OBD port? (Like holding the odometer reset button while turning the key.)
2. Anyone had experience with this scan tool?
3. Any other suggestions?
Thanks, Dave
11-01-2005, 10:32 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
Burnt bulb won't throw an SES light - not familiar with what scan tool your using either - but if it isn't getting any power to it check your "CIG/ACCY" fuse, it also powers the DLC. Try that first.
11-01-2005, 10:46 AM #3SpamcannonGuest
Thanks! I'll check that!!
11-01-2005, 11:11 AM #4Senior Member
- Jul 2005
- Jacksonville, FL
Hopefully that's it - was for me one time when my Predator wouldn't work. Post the code when you read it.
11-01-2005, 11:16 AM #5SpamcannonGuest
Will do!
11-05-2005, 09:27 PM #6
make sure it's a OBD II scanner...if it's OBD I it won't work. And as stated above...light won't throw a code
edit: Just googled your scanner..it is OBDII...hmmmm, not sure why it's not workingLast edited by SeVeReDiStOrTiOn; 11-05-2005 at 09:29 PM.
Question: Equus 3030 Innova Diagnostic Code Reader for OBDII
By KahanaReef in forum Computer & TuningReplies: 9Last Post: 04-25-2010, 12:52 PM -
OBDII code P0430... bad cat?
By BlackSS1 in forum Computer & TuningReplies: 1Last Post: 03-12-2008, 06:20 AM -
3800 v6 obdII p0420 code
By coryprine in forum General HelpReplies: 4Last Post: 12-22-2007, 07:01 AM -
OBDII Code Deletion and Pass Emissions?
By 89LX in forum Computer & TuningReplies: 19Last Post: 12-08-2006, 05:00 PM -
OBDII error code p0420
By delinquent543 in forum Computer & TuningReplies: 8Last Post: 12-28-2005, 08:16 AM
