Results 1 to 20 of 38
    Driving like i stole it!! dafizzman1's Avatar
    Centereach, NY
    1998 Formula
    pacesetters LT's
    is installing these pacesetters really that hard or is it hype??? tricks ????
    If you have the means and the desire, be prepared to do whatever it takes.
    so far:
    suncoast creations functional ram air setup,pacesetter LT's/ORY,magnaflow,pro 5.0,hurst stick,LS6 cam,4:10 gears/stock rear(screaming for mercy!!!)
    -still more to come!!!!!!
    Senior Member Street Lethal's Avatar
    New Jersey
    Isn't too hard at all. A lift makes it much much easier, though....
    Senior Member Rhinohuey's Avatar
    Glendale, AZ
    1999 Trans Am
    Me and a friend of mine did it in about 6 hours. It was the biggest project either of us had done at that point. We just used ramps, stands, and we had 2 jacks. Really, the hardest part is just getting the car high enough in the air to slide the headers in. Everything is cake from there.
    Centereach, NY
    1998 Formula
    got a lift at the shop so itll be easier i hope. thanks!!!
    Senior Member camarojunky74's Avatar
    corona ca
    white, white and pewter
    Rip99SSA4,74Z28M4,02SSM6
    i would recomend using a can of rust penetrans and giving everything a once over the night before tearing it apart, you will save your self a lot of busted knuckles and broken bolts;.
    Centereach, NY
    1998 Formula
    do you actually need to unbolt the mounts or can you do it w/ them in place??
    STAY PUFT thecorrectformula's Avatar
    Delaware, OH
    My brother in Law did a set in three Hours with a lift
    Aug 2006
    maryland
    yellow
    2002 trans am
    I Just did my pacesetters last week. Peice of cake. U dont have to un bolt the motor mounts. I didn't have to even unbolt the sterring shaft or cut nothing they slide right in. But a good thing to do is get some penitrating oil I used PB and give all the bolts a good shot the night befor then shootum again about a hour before. I did mine by myself in my garage on jackstands in about 8 hours. Make sure u get the car up as high as u can.
    Centereach, NY
    1998 Formula
    thanks for the help guys. Monday is d-day!
    corona ca
    ive installed hookers and a pacesetter y pipe, the hooker headers were a nightmare, took all night until noon the next day, had to unbolt secondary air, steering shaft, reciever drier, and a few other things cant really remember!
    Centereach, NY
    1998 Formula
    they're in!!! a bit of a P.I.A. but done! the d/s mount did have to be unbolted to slide it in. but all is together now. now working on this sputtering issue.....
    Member Hot Rod SS's Avatar
    South Carolina
    2000 Camaro SS M6 #3,850
    I'm about to install a Magnaflow cat back system this Friday, and plan to do Pacesetter longtubes and an ORY later, keep us posted on the sputtering thing.
    Centereach, NY
    1998 Formula
    still trying to figure it out!!!
    corona ca
    the sputtering issue, when does it do it? cold hot? idle off idle?
    let me know i can see if i can help you any!
    Centereach, NY
    1998 Formula
    sputters any time im under 2k rpm or heavy acceleration. at first i saw the dipstick tube touching one of the boots. fixed that. no difference. noticed the gasket for the egr pipe that goes into the intake was leaking. gonna fix that this afternoon.
    p.s. i scanned the codes. only O2 codes came up. the car is running extremely rich. at a stop it makes your eyes water. could that be doing it????
    Centereach, NY
    1998 Formula
    update
    replaceing the egr gasket seemed to help eliminate the low end sputtering but i still breaks up after 4k. possible o2 issues? could O2 cheaters help and where could i get them? and if any is from NY do you know of a tuner in the Long island area???
    thanks a lot guys!!
    andrew
    corona ca
    do you have any type of scanner or acess to look at live vehicle data? this would help! but i would say that if you still have the o2's in with the headers and no cats, this could fool the pcm real bad, not only that but i have seen bad exhaust leaks cause a rich mixture as well make sure your not sucking in air, and check for leaks at the head!
    and no i dont know of any tuners out there i am from so cal!
    Centereach, NY
    1998 Formula
    checked for exhaust leaks already. all is good. i dont have diagnostic tools but a cousin runs a shop. he can get me in on monday.
    someone told me that the "o2 cheaters" just plug into the existing wiring and fool the pcm into thinking everything is good. is that how they work?
    p.s. picked up set of wires from local performance chevy dealer. all rubber boot. ill put them in and see if that'll help.
    Centereach, NY
    1998 Formula
    maybe a lead... when i took the wire off the second in on p/s (cylinder 4??) the car ran the same. is it possible that a coil could go bad in the 6+ hours you have it disconnected.
    Indianapolis
    2000 WS6 6spd Hooker LT
    Quote Originally Posted by dafizzman1 View Post
    Sounds like you found the misfire. Make sure you put the plug wire back on both sides all the way.
  1. pacesetters or slp
    By mr_r0bert0 in forum External Engine
    Last Post: 10-28-2008, 04:24 AM
  2. pacesetters on a 99 t/a
    By via sin dios in forum External Engine
    Last Post: 07-13-2007, 07:44 AM
  3. Pacesetters LT
    By 0235thannviSS in forum External Engine
    Last Post: 04-08-2007, 12:44 PM
  4. Pacesetters
    By OnEbAdReDSS in forum External Engine
    Last Post: 02-04-2007, 11:13 PM
  5. Pacesetters on the way
    By Huskerz1 in forum External Engine
    Last Post: 01-16-2007, 09:23 AM
