07-22-2007, 02:16 PM #1Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
How long can you run without a tune after header install?
Want to get long tubes,but I live a good ways from the nearest tuner, about 200 miles. just how long can I go without a tune even if the car runs rich?
07-22-2007, 02:34 PM #2Slow'er'Ass
- Thornton, CO
How ever long the car runs.
Tune isn't a need after LT's. Just something that would maximize the mod.
07-22-2007, 02:44 PM #3UberTapping Friction Pimp
- Mar 2007
- Omar's Tittie Taverna & Grill, Deh Rawod
18D Cock Diesel- 1999 Z28; 98 SS #2043 RIP
I got all my mods done first before I got it tuned. The car ran fine but not nearly as well as it could.
"I am the executioner. When a crime is committed and the exalted state does not take vengeance nor move to punish, then comes time for the executioner to declare himself. I have waited long enough. The criminals are hereby sentenced to death. By fire. By earth. By water."
07-27-2007, 06:34 PM #4Junior Member
- Jun 2007
- Hoyt Kansas
black- 1969 camaro
GM pcms have a beautifull thing called fuel trim: This is a correction factor between what the MAF sensor says is necessary and the actual oxygen level at the O2 sensors, the headers will cause a shift in the efficiency of the motor but with the exception of first start up , the pcm will over timecorrect any(within reason) deviation. I have gone as far as to leave a large vacuum line off and watched the fuel trims correct up to %50 and had a vehicle still run reasonably well.
It wont run perfect mindyou but you wont damage anything.
BBK Long-Tube Headers Install - Going Long
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 09-09-2011, 06:30 PM -
Post LT header install header issues
By ob02z28 in forum External EngineReplies: 20Last Post: 02-18-2010, 04:10 PM -
header install and tune price
By dlmeadows in forum General HelpReplies: 9Last Post: 08-19-2007, 10:52 AM -
Will long tube install need a tune?
By omcar17 in forum External EngineReplies: 15Last Post: 05-24-2006, 01:55 AM
