Results 1 to 11 of 11
07-22-2007, 08:06 AM #1Junior Member
- Jul 2007
- West Virginia
Satin Silver / RED- 02 Acura RSX/93 Transam
Thinking of buying this TA, need some help.
I've been searching for a mechanically sound, relatively inexpensive 93 and up TA that I can use as a weekend car and slowly fix up. I've come across a red 95 relatively close by. It has around 135k on it. It has some extensive engine work and is supposed to be making around 385 HP. Assuming its in halfway decent condition body wise, and mechanically trouble free, what do you all think it might be worth? If it is actually putting down that kind of power, what kind of times should it potentially be capable of?
ThanksLast edited by ziominix; 07-22-2007 at 08:15 AM.
07-23-2007, 03:21 PM #2Junior Member
- Jul 2007
- West Virginia
wow no ideas?
07-23-2007, 03:40 PM #3
should it be in great shape,around 4000 to 5000 range.miles bring the price down.
07-23-2007, 04:02 PM #4
+1. that much at most. miles are too high. if he starts talking about how much money he has in the engine, too bad. Everyone knows you never get that back out of it. the wear and tear of 134k on the rest of the car is not enough to counterbalance the better engine.
07-24-2007, 07:49 AM #5
I could see someone asking 6-7k is it is there babay and they think it is worth more than it is (like most people privately selling there car usually do).
07-25-2007, 04:58 PM #6
I wouldn't pay more that $5000.00 for it especially with that kind of milage on the car. We need more info about the car and possibly some pics.
07-29-2007, 02:14 PM #7Junior Member
- Jul 2007
- West Virginia
I only have a few pics, and the only thing you can see from them is that its red. No close up shots or interior pics. Anyone ever hear of not having a functional reverse gear because of a "bent shift fork"? From what my father, who owns a garage, tells me, the only way you could see that problem would be to have the tranny apart, at which point you'd simply fix it. Thats the only mechanical problem listed. If it simply requires tearing apart the transmission to fix it, no big deal, like I said, dad owns a garage. However if its probably going to require a rebuilt transmission, and he's BS'ing me here, then I need to rethink the $$ argument.
Also he said he's bypassed the heater core. How labor intensive is that to undo?
Thanks again guys for all the input.
07-29-2007, 02:15 PM #8Junior Member
- Jul 2007
- West Virginia
Heres whats been done to it.
ENGINE MODS:
-forged stock crank
-clevitte h-series bearings
-eagle i-beam 6" connecting rods
-ross 90450 forged pistons
-11.2 compression ratio
-gm847 cam
-comp guide plates
-comp hardened pushrods
-comp 987 valve springs
-comp retainers
-comp 1.6" roller rockers
-slightly ported heads (15-20cfm over)
-impala ss head gaskets
-port-matched intake
(accessories and etc)
-meizer hd electric water pump
-melling hv oil pump
-30lb svo fuel injectors
-255 lph walbro fuel pump
-ngktr5 plugs
-airfoil
-ported and descreened maf
-cold air induction by moroso
-160* thermostat
-fuel pressure regulator
-hooker long-tubes/x-pipe/bullet race mufflers/dumped
(drivetrain)
-spec stage III clutch and pressure plate
-summit racing rear end girdle cover
-gm motive 4.10 gears
07-29-2007, 02:22 PM #9ArtistFormerlyKnownAsMac
- Apr 2006
- Indianapolis, IN
All Black- 83, 87, 02 All WS6 T/As
Yeah, with all that, I can see it putting out that kind of HP... What are they asking for?
-Geno
1983 Black WS6 "WindCharger"
1987 Black WS6 "WS87"
Sold the other four f-bodies
07-29-2007, 07:12 PM #10Junior Member
- Jul 2007
- West Virginia
With the tranny problem, too much.
But I think I can negotiate to what I feel is a deal. I'm just wondering how much this problem could potentially run me. Also, any estimates on 1/4 times? I'm assuming somewhere mid 12's shouldn't be too hard correct?
07-29-2007, 07:21 PM #11ArtistFormerlyKnownAsMac
- Apr 2006
- Indianapolis, IN
I've got 342 to the wheels and am at 12.1.. so I would imagine high to mid 11s if it hooks...
Thinking of buying a Mac...
By Tonik in forum Computers / GamingReplies: 4Last Post: 03-20-2010, 04:07 PM -
Thinking about buying these
By JK440T/A in forum Wheels and TiresReplies: 4Last Post: 01-05-2010, 09:51 PM -
thinking of buying a C5
By Popeye1970 in forum Camaro / SSReplies: 8Last Post: 05-04-2009, 07:23 PM -
thinking of buying another one
By chevy1966 in forum ConvertibleReplies: 4Last Post: 02-25-2008, 10:28 AM -
Thinking About Buying a Gun
By FuxOnTheFirstDate in forum Almost Anything GoesReplies: 28Last Post: 05-14-2007, 10:36 AM
