Thread: Split LCA?
    Member Mr Z's Avatar
    Idaho
    1998 T/A A4
    Split LCA?
    After hearing Les Schwab say it might be this and it might be that, I broke down and dropped $95 on a dealership diagnostic of my problem.
    For the last few weeks, whenever I back into or out of a spot, I hear a loud pop from the drivers front. It only happens when I'm stopping to go forward. And then when it comes time to make the first stop after going forward, I hear a much softer pop. It only happens when the car's weight shifts after the initial stop of moving in the new direction. Anyone else ever experience this?
    Pontiac dealers' driveline tech says it looks like my lower control arm has a split in it. They're wanting $700+ to replace it. I was thinking about buying a used and installing it myself. What's the process going to be? Will I need spring compressors or do our cars have 1 piece strut assemblies?
    Member Fastcar's Avatar
    Jersey Boy
    Dark blue metallic
    2000 TransAm
    Are you sure that it isn't bad ball joints or tie rod ends causing the noise? I'd take the car to a good alignment shop ASAP and get a second opinion - cracking a front LCA is not a common occurrance. If the LCA was bad, I'd put a new aftermarket piece in, not just a factory replacement IMO. Besides, if that truly were the cause of your problem I won't drive the car at all! You'd have a much bigger concern with safety issues - what if the LCA failed completely and you lost control of the car? When you get a second opinion, don't tell them what the dealership said to you until after they give you their diagnosis. You don't want to prejudice them and 'steer' them down the wrong path, so to speak. If the LCA is cracked they should spot it easily. Good luck!
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    kinda sounds like the bolts are loose causing it to shift around. my lower control arm front bolt was loosing causing that same sound. also, check the rear bushing in the arm. it is common to go bad.
    Idaho
    1998 T/A A4
    I went under there today to pull off my pads and rotors and cant seem to see anything. I had a guy at work telling me that it might be the bushings too.
    Idaho
    1998 T/A A4
    Forgot to update on this.
    Mrr, you were right about the bolts. I had a loose one on my driver's side front caliper bracket. I made sure every bolt was properly tightened when I was putting my brakes back together and I haven't heard the popping noise in the last 2 weeks or so. I'm so glad I can rely on my local dealership to properly diagnose problems... Thanks for saving me $700.
    orlando, fl
    2014 camaro 2ss/rs
    anytime
  1. For Sale: 1971 split bumper Z28 Camaro
    By Bbbcena in forum Vehicles For Sale / Trade
    Last Post: 11-21-2011, 04:12 AM
  2. Hitler's Reaction to the Oasis Split
    By SiggyZ in forum Almost Anything Goes
    Last Post: 09-10-2009, 11:50 AM
  3. split-lock header bolts
    By barryTA in forum General Help
    Last Post: 01-17-2007, 04:31 PM
  4. Split exhaust rear valance?
    By Tide in forum GTO
    Last Post: 11-02-2006, 12:00 AM
  5. mild cam with split pattern
    By 99WS6TA in forum Parts Wanted / Trade
    Last Post: 01-18-2006, 06:20 AM
