Results 1 to 20 of 28
    Junior Member quick777's Avatar
    Delaware
    2002
    what should i run with a 100hp shot???
    what should this run in the 1/4 mile?? 2002 Vette A4 trans 273 gears, only mods are a Vortex cold air intake, 100hp wet shot of nitrous no tune, Mickey Thompson et drag tires, are 11s possible?? What et and mph will i run?? D/a is going to be in the +2000 range saturday
    no more 4th gen secondgearscratch's Avatar
    Jun 2006
    St. Louis, Missouri
    2000 z28
    Quote Originally Posted by quick777 View Post
    i dont know about the altitude change but i bet a low low 12. i cant see you breaking 11s with just 100 shot but i could be way off. pull a good 60 foot and its possible.
    sorry i dont have any more info for ya. the one to ask would be mrr23.
    Delaware
    2002
    before the nitrous, spinning the stock runcrap tires i ran a 12.79 at 111mph, now with drag tires and a 100hp shot what do you think i will run this weekend??
    Jun 2006
    St. Louis, Missouri
    2000 z28
    11.70s with a good 60 would be my conservative guess.....
    are they mickey slicks or are you running radials?
    what gears?
    Delaware
    2002
    Quote Originally Posted by secondgearscratch View Post
    what gears?
    they are the non radials 26x11.5x17..... 273 gearing
    Delaware
    2002
    heres a picture of the nitrous setup
    NW Chitown
    2002 WS6
    low 12s, MAYBE high 11s IMO.
    Those gears are going to hurt your 60'....
    GL man! Let us know how it goes!
    -Eagle
    | '02 WS6 M6 | KOOKS/ORY | LC-1 | LOU'S SS | UMI SFCs | BMN LCAs & RELOC's | Hotchkis STB | HSW 150 shot | Lid | 42# Lucas | HPTuner Pro |
    NW Chitown
    2002 WS6
    Also, what RPM are you going to spray at? Going to hit it out of the hole in 1st?
    Make sure you dont bog the motor down when you're @ low RPMs while spraying!!! I've seen a vette just like yours pop into flames (intake backfire) @ the track...
    3000RPM should be pretty safe in 1st...
    Delaware
    2002
    Quote Originally Posted by Eagle View Post
    spraying at 2500rpm in first gear......do you know if that backfire was because of the low rpm for sure?? or did the guy forget to turn off traction control?? running nitrous with traction control on is a no-no
    NW Chitown
    2002 WS6
    He had moved about 10ft off the line and it went BOOM. Not positive... but 2500 sounds pretty low to me on 273s...
    Where's mrr when I need him...
    -Eagle
    Delaware
    2002
    -Eagle
    i always sprayed my truck at 2500rpm or less, went through 38 bottles with no problems using a 150hp shot, stock motor, over 5000 pounds
    heres a video of me spraying at well under 3000rpm in my work truck, listen for when the nitrous comes on just after i launch.....copy and past the link for the video
    http--home.comcast.net-~suzukirules-Hemi777_12.49.wmv
    NW Chitown
    2002 WS6
    Lookin good man! Although it has a cast alum intake... yes?
    I'm just lookin out for ya! GL man...
    -Eagle
    Delaware
    2002
    -Eagle
    thanks.....i might wait until 3000rpm for the first few runs
    truck has a plastic intake just like the ones on the ls1 motors
    NW Chitown
    2002 WS6
    What gears in that PU?
    Delaware
    2002
    stock 392 gears
    NW Chitown
    2002 WS6
    Ah, and there it is!
    Delaware
    2002
    theres almost 2000 pounds more on the truck that holds the gearing and rpm down
    d
    2002 z28
    get a stall convertor and youll be in the 11's with that IMO
    Delaware
    2002
    just got back from the track, first time out with the nitrous, after taking the advice from others i didn't spray to well after the 60ft mark because of my stock A4 trans and 273 gears so that only netted my 1.90 60ft times, time to get a converter so i can spray when launching for much better 60ft and 1/4 times, heres what the time slip shows i will post it tonight when i get it scanned.......with a 122.42mph what kind of times will i run with a 3600 converter?? i was only spraying a 100hp shot today, plans to spray a 200hp shot soon........
    60ft...1.90
    330ft...5.04
    1/8....7.63 at 96.10mph
    1000ft...9.82
    1/4....11.70 at 122.42mph
    d
    2002 z28
    thats some good numbers
  1. 100hp Bolt-On Addition - The Buick 350 Turbo Kit
    By Ed Blown Vert in forum General Help
    Last Post: 06-01-2012, 05:00 PM
  2. Surging sensation in 3rd? HSW 100HP wet
    By Eagle in forum Nitrous
    Last Post: 05-02-2010, 04:28 PM
  3. Behold, 100hp!!!!
    By smokiechicago1988 in forum Multimedia Section
    Last Post: 11-23-2009, 04:33 PM
  4. Mopar B-Motor - 1,100HP Mopar - Engine Tech
    Last Post: 02-24-2009, 09:00 PM
  5. What is the difference, besides the 100hp???
    By KITT#42 in forum Firebird / WS6
    Last Post: 11-20-2006, 12:42 PM
