Results 1 to 19 of 19
    Junior Member CorvetteZ06C5's Avatar
    Iowa
    Corvette C6 OEM wheels On 2000 camaro
    Will OEM front 5-spoke C6 wheels fit fine all the way around?? I know that the rear is like a 78mm offset and the front have like a 58mm or someting?? I know that if you get the rear rims that i will need to get spacers so i thought what about putting 4 fronts on instead if the offset is right.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    i have these on the wife's car. they rub on the rear inside. i banged inward where they rubbed going straight. they rub around corners still. so, if you get four fronts, you'll be good to go. if you get the rears, a 1" spacer is in order.
    Iowa
    Is the offset the same for the 5-spoke base and 10-spoke Z06 wheels or does the Z06 verison have a different off set? The base rims are 18X8.5 and I think that the Z06 are 18X9.5? I know that on the base rims I can run 245/40-18 without change my speedometer and on the Z06 rims I can use 275/35-18 and not change the speedomter. If I get the Z06 rims will I have any problems running 275/35-18 like rubbing or should I stick to the stock width of 245??
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    the offsets for the 18x10,5 are identical for both C6 and C6-Z06 wheels.
    For the skinny wheels, i don't know.
    Eugenio_SS
    Iowa
    if i run front Z06 rims with 275/35-18 will i have any rubbing issues
    Jun 2002
    Montreal, CANADA
    triple-black
    when you say z06, i assume you say c6-z06 and also 18x10.5
    they are +58mm offset wheels.
    I run them w/ 315/30-18 and have no issue in any corner.
    rear: use a 1/4" spacer
    front:1/2" spacer in the front (on stockish brake systems)... but since i have Porsche brake system, no spacer for me in the front.
    for more information and pix: http://www.ls1.com/forums/showthread.php?t=53622
    I have the C6, not the C6-Z06... but offset and sizes are identical.
    They are quite inexpensive @ http://www.lmperformance.com
    Iowa
    I think that Im going to get 4 C6 5-spoke wheels the 18X8.5 and run 245/40-18 on all four corners. Do u know if I will have buy any spacers??? I also want to get the C5 Z06 brake conversion will I have any prblems running C5 calipers with C6 wheels??
    Jun 2002
    Montreal, CANADA
    triple-black
    Quote Originally Posted by CorvetteZ06C5 View Post
    for the spacers, i need to know what the offset is...
    I'd put at least wider wheels in the rear... instead of the 8.5 on all 4... but it's a personal thing.
    As for the brakes, no problem.
    Iowa
    the offset is 56mm
    Jun 2002
    Montreal, CANADA
    triple-black
    no need of spacer in any corner... fit like a glove.
    Iowa
    know any were to buy c6 oem chrome 5-spoke
    Jun 2002
    Montreal, CANADA
    triple-black
    Replicas can be found everywhere.... oem, i guess have to be purchased through GM, a dealer, or used.
    There is http://www.gmpartsdirect.com
    Iowa
    what about theses on all four corners http://cgi.ebay.com/ebaymotors/18-x9...QQcmdZViewItem
    Jun 2002
    Montreal, CANADA
    triple-black
    look nice, but those aren't oem, they are replicas.
    Iowa
    right just the last one that i posted is OEM
    Jun 2002
    Montreal, CANADA
    triple-black
    so it'll cost close to $500 / wheel while you can get them under $200 for replicas. I'd go w/ the replicas... if you gonna spend 2k$ on wheels, get nice forged wheels.
    Iowa
    people r selling polished sets on ebay but i only want the front set
  1. 2000 SS Camaro Wheels
    By ctchap70 in forum Wheels and Tires
    Last Post: 10-04-2016, 08:06 PM
  2. C6 Wheels on a 2000 Camaro SS
    By Camaro SS 00 in forum Wheels and Tires
    Last Post: 08-22-2011, 05:44 PM
  3. Question: Corvette wheels fit on a Camaro?
    By amysboxers in forum Wheels and Tires
    Last Post: 02-17-2011, 04:33 AM
  4. Wheels Camaro Corvette C6
    By CorvetteZ06C5 in forum Wheels and Tires
    Last Post: 07-18-2007, 04:02 AM
  5. 2000 camaro ss vs 2000 corvette
    By 99-SS-Conv in forum General Help
    Last Post: 04-03-2007, 08:17 AM
