    Bay Area, CA
    1999 Formula
    Exclamation replace radiator 1999 formula
    I need to replace the radiator on my 1999 Formula. Any install advice would be helpful. The Haynes manual says the air conditioning system and condenser must be removed with the radiator. But another post on this site did not mention that. Anyone know what must be done? Thanks for your help, I have never replaced a radiator before and hate going into a project without some info.
    Kurt
    408 ci + 4000 stall = fun lancesT/A's Avatar
    Abilene Texas
    2002 SS
    replacing the radiator is easy, once you start taking it out you will realize how simple it is so dont worry about it. as for the condenser it will come off with the radiator because they are attached. well good luck.
    Bay Area, CA
    1999 Formula
    do i have to discharge the air conditioning system. The haynes manual also mentions this. Thanks for your help lance
    kurt
    Don't take the condenser out. You can do it without cracking the line on the a/c so you don't have to recharge it. Go to ls1howto.com and look under the "f-body heads/cam swap". There's a section telling you how to remove the radiator. Not a hard job but those tabs the condenser sits in can be a pain to get loose. The condenser basically sits in tabs on the radiator just like the fans do. Not hard to get out, just takes some patience. Getting them back in is worse than getting them apart but it's not a big deal, just takes a little time and patience. Other than that it's pretty straight forward.
    Abilene Texas
    2002 SS
    i didnt mean to take the condenser out just take it off the radiator sorry for the confusion
    Bay Area, CA
    1999 Formula
    right on, thanks for the help guys. Always like to learn to do it myself than just taking to a shop. If there are any other "tips" that anyone can offer, please let me know. Thanks again!!
    Kurt
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    remove the lower radiator hose with the radiator. it'll be way easier to remove it from the radiator after it is out of the car.
  1. Time to replace the radiator
    By Lunatikgixxer in forum General Help
    Last Post: 08-01-2011, 05:24 PM
  2. 1999 Formula WS6
    By vanmar in forum Showcar and Detailing
    Last Post: 10-05-2009, 08:01 AM
  3. How to Replace the Radiator in your LT1
    By 95camaroZNC in forum LT1
    Last Post: 09-24-2008, 05:07 PM
  4. 1999 Formula Ws6 1LE WOW!
    By 96Firebirdformula in forum Firebird / WS6
    Last Post: 04-15-2008, 12:58 PM
