    Tennessee
    Black/Black
    2004 GTO
    Starting issue on an 04 GTO when cold?
    Im not quite sure what may be causing this and the dealer somehow forgets to check this each time I drop it off
    When the engine is hot it will start fine. You turn the key and it fires right up smoothly
    When its cold however it take a couple extra seconds to start and theres sort of a clunking I can feel when it starts. A few times it wouldnt start at all on the first turn and I had to try again. Dirty fuel injectors maybe?
    Junior Member speeddemon100's Avatar
    Aug 2006
    CT
    Yellowjacket
    05 GTO M6
    how many miles?
    most likely the lifters pumping up with oil-the LSx makes ALOT of noise when cold
    Tennessee
    Black/Black
    2004 GTO
    It has 23,000 on it now and I bought it back in February with 20,000 miles. (I know I dont drive a lot)
    Its the automatic transmission as well if it makes a difference.
    Im just worried about any repairs after the 3/36 ends in December
    Aug 2006
    CT
    Yellowjacket
    05 GTO M6
    could be dirty injectors but I doubt it unless you use horrible gas
    not really sure what it is,but mine starts everytime with the Optima battery
    it could actually be your battery and nothing wrong with the mechanical goodies
    Senior Member GOT1GOAT's Avatar
    Newcastle,De.
    04 GTO QuickSilver
    95 MarkVIII wifey white
    Check your battery voltage in the DIC. Hold menu and set buttons then turn the key to the on position (not started) and scroll using the menu key til you get to batt. voltage. Mine reads 12.4v.
    04/A4 Quicksilver
    Magnflow catback-Resonator delete
    K&N drop in
    SAP front Grills and 05 hood
    Limo tinted windows-Gets me pulled over alot
    Diablosport Predator (RWTD) tune.
    Tennessee
    Black/Black
    2004 GTO
    I tried it out and it read 12.2 volts so I guess it checks out ok
    Its actually been running fine for the last week or so
    I think it may actually be related to a bottle of fuel injector cleaner that I put in the tank. After I refilled it with 93 octane only again its been running ok
    Newcastle,De.
    04 GTO QuickSilver
    The inj. cleaner would not cause this and this sounds odd especially not throwing a cel.
    Awaiting Activation 5.7literMustangEater's Avatar
    Hedgesville, WV
    Torrid Red
    2004 Pontiac GTO
    It is your battery!!!
    Quote Originally Posted by redspeed View Post
    Your voltage for your battery should read 12.5v-14.5v. Anything lower means that the battery is being drained. 12.2v probably means your battery needs to be charged back up. Take it to AutoZone and have them carge it up for you. It is a free service. That should do the trick. My GOAT had some problems starting and it turned out that the battery was low on charge so I had it charged and everything worked perfectly.
    Tennessee
    Black/Black
    2004 GTO
    It reads 12.2 in the on position, then jumps to 14.2 or 14.4 when I start it. I havent tried charging it yet though
  1. Starting Issue
    By DaEvil in forum General Help
    Last Post: 03-01-2013, 02:53 PM
  2. starting issue
    By joevee1446 in forum Firebird / WS6
    Last Post: 03-07-2011, 07:22 AM
  3. Issues When Starting In The Cold
    By surfinjoe in forum GTO
    Last Post: 01-26-2009, 09:05 AM
  4. Question: Starting Issue
    By Wesman in forum GM Trucks
    Last Post: 06-12-2008, 08:10 PM
  5. Replies: 2
    Last Post: 01-25-2007, 10:05 AM
