Results 1 to 20 of 26
    Senior Member Rhinohuey's Avatar
    Glendale, AZ
    1999 Trans Am
    Automatic Shift Pattern
    Whats with the shift pattern in all of the new cars with automatic transmissions? The ones where they like zigzag left and right between Park and Reverse and Neutral and Drive instead of just sliding straight back to go to the desired gear. I just had to rent a 300c with a shifter like this, and I hated it. I couldn't go between the gears without actaully looking down at the shift pattern.
    Glendale, AZ
    1999 Trans Am
    Just like this one here.
    Rockford, IL
    yea i wannaknow too. how gay
    In the janitors closet
    One more and I'm gone....
    beats me....i guess to "look" cool
    Wisconsin Rapids, WI
    1999 Z/28 M6
    maybe to make you feel a lil better about buyin the auto instead of the manual
    Glendale, AZ
    1999 Trans Am
    Haha, I also tried out the auto stick. Its pretty much the gayest thing ever. Every time you hit the shifter, it takes like 2 seconds to actually shift. About the only thing its good for I guess is just to lock it in a lower gear or higher gear.
    Rockford, IL
    gay as aids
    Super Senior Member derrinx's Avatar
    Feb 2006
    NYC
    2000 Trans Am WS6
    theres actually a very good point to it.... in the old ones where you just slide back and forth its very easy to accidentally miss the selection your trying to make... with the new ones they look cool, feel cool, and lock you into the selection you are trying to make, and once your used to it its no problem..
    remember "his and hers" shifters?? Now they're just "hers and hers".
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Yeah those were bad ass!! I even liked the 83-84 Hurst Olds better they put the lighting rods in them. The kids probably have NO idea what we are talking about.
    Rockford, IL
    no i dont have a clue lol.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Here is a link so you can see what the Lighting Rods look like.
    It was like a Lenco as you would just keep pulling a different lever for the next gear when manual shifting.
    http://cgi.ebay.com/ebaymotors/Hurst...27633191QQrdZ1
    Glendale, AZ
    1999 Trans Am
    Quote Originally Posted by LS2Tuner View Post
    I saw one of those once and I tried searching everywhere for it and couldn't find it. How do they work? I see they are used for an automatic transmission, but what is the purpose of the other 2 levers? The one I saw had a red tag thing on the additional 2 levers that said something like Don't move these levers until you have read the owner's manual.
    Glendale, AZ
    1999 Trans Am
    Wow, I just found this site when I searched for "his and hers shifter".
    http://hrst79.tripod.com/79hrst/id11.html
    Thats pretty sick. So you can basically choose to leave it in high gear all the time and let the transmission shift automatically or you can use the lever to shift it manually, right???
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by Rhinohuey View Post
    Basically it's normal shifter all the way to the left......P,R,N,O/D,D
    If you wanted to shift it manually you would pull the far left lever and pull it and that would put it in manual LOW or first.Then grab the middle lever and pull it and it would shift to second.Then pull the third into drive all the way back and it was in drive.
    Exactly. Those Hurst cars were real cool. Not the fastest but cool cars to drive and mod with big bottle.
    Do they still make bump shifters??
    Indianapolis
    2000 WS6 6spd Hooker LT
    That would be the His and Hers, eh? I also had another shifter for an AT out of an early 70s Pontiac, if you were in manual 1st, all you had to do was bump it hard to the right and up, it would only move one gear, not all the way into Neutral.
    Had the His and Hers in my .030 428 '67 GTO. Top speed was 118 MPH, 5700 RPM, no overdrive! Got there fast as hell too.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    You would be referring to a ratcheting shifter. Yes they are widely available...
    I like the "bump" name thats a first for me......
    I looked it up after posting that and found the b&m ratcheting shifter. I've always just known it as a bump shifter. I can't believe you haven't heard that expression....you're not exactly a spring chicken.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    I think it all has to do with where you live and the slang people speak.
    It is night and day from Indiana to out on the westcoast were I'm at now.
  1. Automatic Shift boot and new shift handle
    By stew215 in forum Appearance Section
    Last Post: 04-21-2011, 02:04 PM
  2. shift kit for automatic
    By 99ta/cg in forum Automatic Transmission
    Last Post: 02-08-2011, 01:11 AM
  3. Automatic shift knob
    By PHXLB in forum Firebird / WS6
    Last Post: 02-26-2010, 04:38 PM
  4. shift pattern plaque from TSS
    By Poppn in forum Appearance Section
    Last Post: 04-17-2009, 10:34 AM
  5. Automatic Shift Knob
    By GULLETT17 in forum Appearance Section
    Last Post: 03-17-2008, 08:06 PM
