    Its the Hotwad StylesMcKnob's Avatar
    Twentynine Palms, CA
    2000 Formula 6spd
    Koni single adj. whats the difference?
    whats the difference between these two shocks?
    http://www.hotpart.com/index.php?p=show&id=84
    http://www.hotpart.com/index.php?p=show&id=149
    someone help me out they are both koni sa rear shocks for the 93-02 fbodys
    Dawson, IL
    2000 Trans Am
    8241-1140 is the 4th gen koni sa, 30-1265 is the 3rd gen koni sa - both will work on the 4th gen but I've seen that the 4th gen is easier to adjust
    Correct, to adjust the 3rd gen rears you need to uninstall them from the car where a 4th gen rear has the adjustment at the top of the shock so all you need is to pull back the carpet and use the adjustment dial.
    2000 Formula 6spd
    thanks ill be getting 4th gens
  1. Question: whats the difference in koni sing adj and double?
    By bpopham22 in forum Suspension and Handling
    Last Post: 04-15-2010, 01:37 PM
  2. Koni Sport (Single Adjustable) question
    By NetrixTardis in forum Suspension and Handling
    Last Post: 01-12-2009, 06:02 AM
  3. Koni/Strano: what a difference!
    By sfletch2000 in forum Suspension and Handling
    Last Post: 04-29-2008, 01:53 AM
  4. Hawk HPS front brake pads and Koni Rear single adjustables
    By JAGUAR5822 in forum Parts For Sale / Trade
    Last Post: 08-13-2007, 04:03 PM
  5. difference between double & single roller chain
    By Semperfiws6 in forum Internal Engine
    Last Post: 08-06-2007, 04:50 PM
