    Chapel
    Guest
    Talking Newbie post: High mileage LS1. Long term and purchase questions
    Hi, this is my first post.
    I've found a 1998 Z28 6spd for $8000. It's a nice car, but has 100k miles.
    I'm really only familiar with old BMWs (which, for the record, are very very reliable)
    I figure the Small Block Chevy V8 has to be mechanically reliable, but what other things could go wrong with a 100k mile car like this?
    What things should I be looking at before I purchase one?
    if there's a FAQ on purchasing these, could someone point me in the right direction? I didn't see anything when I searched.
    Thanks in advance
    mexusa
    Guest
    So im new too, but i can tell you that i have a 1994 V6 and it has more then 200,000 miles and i have never had problems with my engine.. i had to replace the clutch once, and at this time i need to buy a new propeller shaft, but other then that that car has been worth every penny i paid for it. (considering i drive it like a stole it)
    PS if you can tell me where i can find a propeller shaft for my 5 speed v6 i would appreciate it. Its easy to find drive shafts for z28s but apparently mine is the only camaro v6 ever that has ever needed a propeller shaft, cause no one sells used ones.
    Chicago
    1997 Camaro SS
    in all honesty, 8k for 100k 98 isnt that good of a deal. if it was 6 it would be worth it, but honestly, you can get an ls1 with 50k for 9-10k, 1998 or 1999. just wait it out and shop around, i swear you'll find a better deal.
    Senior Member Hurley711's Avatar
    Earth
    414 RWHP 395 RWTQ
    00 Black Ram Air Trans Am
    There's 2 for you above click the linkies, TA and a Z28 both under 100k miles, both within a reasonable distance from you
    kenosha
    1999 camaro
    one of my buddies is selling his 99 z-28 with a decent amount of mods(which includes a 4"cowl induction hood) and is kept stored for the winters has 50-60 thousand miles on it. The bottom line is $9,500.
    Junior Member Pete2k_Z28's Avatar
    nj
    How did this wind up in the V6 forum????
    Moving back to Help
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    Quote Originally Posted by Chapel
    That's not really that great of a deal, keep searching...that car is probably only worth around $6k.
    This is a new site, we just lost our old one, so it will take a while for a good wealth of information to pass through this site and become searchable once again. You'll want to shop for an LS1 car like you would shop for any other car...very carefully. Especially with an LS1 you'll probably want to make sure it hasn't been modified just to make things easier. Take a look at the air filter, see if that has been changed to an aftermarket one...make sure it's got original exhaust components (98-00 cars will have EGR/AIR). No random holes drilled here and there, and everything in its original place.
    Some LS1 cars will have piston slap, that is somewhat normal. Almost every car will have a leaking pinion seal, that isn't a huge deal either. When you drive a manual, see that it goes smoothly into every gear...like I said it's basically just like shopping for a regular car, check out everything mechanical very thoroughly!
    Junior Member PIMP_2's Avatar
    99 Camaro Z28 LS1
    http://img355.imageshack.us/my.php?image=10003380cq.jpg
    I picked this up last week for less than 10,000. '99 Z28 LS1 6spd T56, 45,000 miles. Nothing at all wrong except very small wear on driver side leather.
  1. Help: Short term and long term fuel trim readings can ANYONE help?
    By DaytonaBlues in forum General Help
    Last Post: 10-20-2013, 04:21 PM
  2. Ressurecting Trans Am from Long Term Storage
    By Rhinohuey in forum General Help
    Last Post: 12-01-2012, 10:28 PM
  3. Question: Whistler Mod - long term durability?
    By davebowtie in forum Appearance Section
    Last Post: 07-06-2009, 08:55 PM
  4. rear o2's = long term fuel trim?
    By M-Ten in forum General Help
    Last Post: 01-27-2008, 02:45 PM
  5. Long term storage question
    By 02 HAWK in forum General Help
    Last Post: 10-23-2005, 03:55 PM
