Results 1 to 19 of 19
Thread: Spark Plugs?
    Preferred Member CWW17's Avatar
    Central Illinois
    Black | Black
    '07 Z06 | '98 WS6
    Spark Plugs?
    I'm about ready to put some longtubes in and was wondering what spark plugs I should buy... Seeing as how I'll have a little better access to them with the headers off... Thanks!
    Boosted Foolz
    Buffalo
    BlAcK
    1998 FiReBiRd FoRmUlA
    NGK TR6's for Nitrous / FI setup
    NGK TR55's for N/A setup.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Iridium
    Then you won't have to change them every 12K
    Vicksburg. Ms.
    pewter
    99 Trans Am
    Thumbs up
    At about 15,000 miles on my TA I installed the ngk TR55 plugs because just about everyone on the board uses them.I changed my plugs last week with the car having 35,000, but I went with the AC41985 plugs, which is a stock plug.I have found that it idles better to me and I want have to change them as often.The TR55 may be better but I just can't deal with the content plug changing. I want be changing them again until I get about 75,000 miles on it.The car sits running and you can't even tell it unless you tap on the gas. I am sold on the stock plugs.
    NW Chitown
    2002 WS6
    Quote Originally Posted by 98_Formula View Post
    +1
    Although there is something to say for stock ACDelco replacement plugs if a stock plug fits your application.
    -Eagle
    Member danziger's Avatar
    Aug 2006
    Chesapeake, VA
    Le Mans Blue
    2004 Z16
    I like the NGKs. I'm currently using TR6s at .038 gap for the 383/spray...
    d
    2002 z28
    havent change the plugs yet on a f body only on my other cars. is it true that you have to do the # 8 plug from under the car.
    explain the install if you can. i have 35,000 miles soo far and getting ready for NX soo i know TR6
    d
    2002 z28
    Quote Originally Posted by CWW17 View Post
    make sure you buy some anti - sieze for the threds of the plugs. and some sealer grease for the boots and top ends. only like 4.00 if you buy the small one time packs but great for the later use and utillitiy
    NW Chitown
    2002 WS6
    Quote Originally Posted by greatwhiteZ28 View Post
    NO. I'm 6', 230 and even I can get my pudgy hands in there.
    d
    2002 z28
    soo a;; threw the top ah
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    www.installuniversity.com
    Junior Member sweet2000's Avatar
    Kentucky
    pewter
    2000 camaro ss
    Changed 3 sets of spark plugs
    I have found out that taking the coil packs off makes everything much easier. Although it might take 30 minutes longer but it will save your hands.
    Central Illinois
    Black | Black
    '07 Z06 | '98 WS6
    thanks everybody for the info!
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    It is ALL motor combo?
    Central Illinois
    Black | Black
    '07 Z06 | '98 WS6
    yeah... i dont have any power adders
    Member va2001ss's Avatar
    Northern Virginia
    2001 Black SS #5228
    NGK TR55 this time. Last change I used the TR6's, I liked those better being a cooler plug, the the TR6's seemed to prevent knock a little better.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    I would run the A/C Delco Rapid Fire #12's for a ALL motor combo.
    Central Illinois
    Black | Black
    '07 Z06 | '98 WS6
    so you would recommend those over the NGK TR55 IX's?
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Yes I do. I don't really care for the NGK's myself. If you really want a irdium plug which some do than I put the Denso in my customers and that part # is 5325.
  1. Enerpulse Pulstar Spark Plugs - Supersize Your Spark
    Last Post: 03-15-2013, 09:00 PM
  2. Question: Spark Plugs
    By 10erg01 in forum General Help
    Last Post: 03-27-2010, 08:53 PM
  3. What kind of oil 5w30& spark plugs&spark plug wire
    By ROMERO98Z28 in forum General Help
    Last Post: 09-01-2009, 01:50 PM
  4. spark plugs, tr55 iridium or plane tr55 plugs?
    By got-a-ls1 in forum General Help
    Last Post: 02-09-2006, 06:06 PM
