Thread: rpm's through speaker???
06-30-2007, 09:08 AM #1
this is caused by my plug wires right? simple fix get new wires and the "wee" voice will stop playing from my speakers right? just want to be sure before i get some more, my current wires have around 40 thousand miles on them.
06-30-2007, 07:27 PM #2
06-30-2007, 07:30 PM #3Slow'er'Ass
- Thornton, CO
Bad ground.
Somewhere. Check headunit first.
07-01-2007, 12:19 PM #4
As Mr. Luos says above, and also if you have an aftermarket amp and your signal wires (rca's) are routed too close to power wire this noise interference can occur.
07-01-2007, 07:31 PM #5Member
- Oct 2006
- Oklahoma City
00 LS1, WS6, V8 Gremlin- 96 & 98 GTPs, 64 'Cuda
There are primarily three types of radio interference that can come from the car - ignition noise, alternator whine and on occasion whine from some electrical accessory.
Ignition noise is mostly pops and most prominent when the radio is set low on the AM dial, alternator and other electrical interference usually attacks AM, FM, tape &/or CD equally.
After verifying eveything's well grounded you can attack the problem. Ignition noise is usually plug wires or a failing coil. Alternator whine can be a failing alternator but it usually sneaks in when one has power amps. The quality of and where you ran the low level audio wires to the amp is most often the culprit, however some less well-made amplifiers don't have sufficient filtering. One of those large caps close to the power amp may help as will adding toroidial coils around the main alternator wire. You can get these from Radio Shack that just snap on, they're used on computer monitor cables but aren't as effective as the true large toroidial cores you have to remove the wire to install.
Make darn sure the engine block is connected to the car body is connected to the battery negative terminal is connected to the engine block terminal - kind of a triangle arrangement.
If you ran a negative wire from the front to the trunk make sure it's grounded to the car body in the rear.
07-01-2007, 07:36 PM #6
hmm, it sounds to me like a bad ground, i'll check my aftermarket head unit, and my system setup for a bad ground. thanks a lot!
07-04-2007, 11:41 AM #7Junior Member
- Dec 2005
- Washington Pa
White- 2002 WS6
I would check your wires also, I had a problem similiar to this and that was the cause
2002 white WS6, M6 N/A full weight 11.30@124
2007 TBSS AWD 14.20@98 bone stock
07-04-2007, 12:27 PM #8
This problem is simple and very common in the world of car audio. Poor ground's on either head unit (particularly pioneer's) or On your RCA's.
Sometimes this is best fixed by running your own external grounding wires to these components
Best Speaker that will fit?
By Smkn_TA in forum Stereo and ElectronicsReplies: 1Last Post: 03-16-2009, 05:14 PM -
Speaker mod...
By Brad(WS/Z0.6) in forum Firebird / WS6Replies: 19Last Post: 02-05-2009, 06:47 PM -
Question: Speaker out!
By ibh182 in forum Stereo and ElectronicsReplies: 2Last Post: 01-20-2009, 01:42 PM -
Speaker box for '02 WS6 TA
By jag42420 in forum Stereo and ElectronicsReplies: 4Last Post: 09-08-2006, 07:01 AM -
Need Speaker
By Nicbmann in forum Stereo and ElectronicsReplies: 2Last Post: 10-04-2005, 02:32 PM
