Results 1 to 13 of 13
Thread: Rubbing problem
06-28-2007, 07:44 AM #1Impounded
- Mar 2007
- Milwaukee
Red- 2000 Trans Am
Rubbing problem
When i turn left at around 20 i hear and feel that my tire is rubbing and faster or slower it doesnt rub. My rims are stock my tires are 245/50 so there not large.
06-28-2007, 09:02 AM #2
Hit any potholes or do a curb check recently?
Could be alignment is off.
Also, Check your bushings. Make sure none are bad.
06-28-2007, 11:54 PM #3Road Race Addict
- Oct 2005
- Kansas
White- 1999 Firebird Formula
It has to do with the fact that the stock panhard bar flexes. When autocrossing and turning left on some corners my right rear tire would rub with a stock wheel and tire size. It's not rubbing where you think it is. If you look inside your wheelwell towards the frame area you'll most likely see a shiny spot where the inside of your tire has been rubbing. The reason its probably not happening at higher speeds is the suspension is being loaded differently an your tire is farther up in the wheelwell At slower speeds your just not putting any real load on it at all.
I would get under the car and inspect the pan hard bar, mountings and bushings. And as mentioned in the previous post get your alignment checked. Although theres nothing to adjust on the rear of these cars when stock. A good adjustable aftermarket panhard bar will allow for adjustment and therefor better alignment. As long as your not racing in a stock class that doesn't allow such changes that would be my suggestion.
As a side note. the mounts for the panhard bar on the body are fairly bogus looking. I don't know if anyone has had trouble with the mounting points but they do concern me.
06-29-2007, 03:08 AM #4
That brings up a good question.
Where is the rubbing? Front or rear?
I didn't even consider the rear when you had asked. I just assumed front cause you said turning.
06-29-2007, 06:09 AM #5Impounded
- Mar 2007
- Milwaukee
Red- 2000 Trans Am
Its the front left
06-29-2007, 12:44 PM #6
Stock tires are 245/40/17 - don't think 50's should make it rub thou.
06-29-2007, 12:53 PM #7
06-29-2007, 01:27 PM #8Impounded
- Mar 2007
- Milwaukee
Red- 2000 Trans Am
Yeah but i have always had this size tire and it didnt happen efore i got it back from the dealership when they put my new ls1 in it.
06-29-2007, 02:46 PM #9Road Race Addict
- Oct 2005
- Kansas
The front, I assumed the rear because thats where I had problems with stock size tires and wheels. My Bad! Still get under the car a look for a shiney spot. Sounds like they didn't get something reinstalled correctly.
You can also chalk the inside sidewall of the tire and tread area and go take a couple of corners and stop and look to see where the chalk shows up. Sidewalk chalk is cheap and washes off easily!
06-29-2007, 02:48 PM #10Impounded
- Mar 2007
- Milwaukee
Red- 2000 Trans Am
Ty for all the help im gonna look at it but i aint paying for shit im gonna go tell that dealership to fix this shit since they caused it.
06-29-2007, 08:01 PM #11
06-30-2007, 08:31 AM #12
06-30-2007, 12:54 PM #13Impounded
- Mar 2007
- Milwaukee
Red- 2000 Trans Am
Well im alot lower than a ws6 trans am. But it just started since i got it back so i dont think its rubbing.
Help: Wheel Rubbing Problem
By 90ARAPAJ in forum Firebird / WS6Replies: 5Last Post: 04-10-2012, 10:56 AM -
Intake lip/box rubbing
By Soltakr in forum General HelpReplies: 8Last Post: 09-22-2007, 02:13 PM -
315's rubbing?
By clint195 in forum Wheels and TiresReplies: 5Last Post: 01-17-2007, 12:46 PM -
Rubbing problem now..... Or something Else. Help Please.
By FireBirdzx28 in forum Firebird / WS6Replies: 3Last Post: 07-16-2006, 09:37 AM -
Need Help with some rubbing
By 02_WS6 in forum Suspension and HandlingReplies: 7Last Post: 08-20-2005, 03:08 AM
