Results 1 to 20 of 74
06-27-2007, 09:01 PM #1Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
Parting out 1995 Firebird Trans Am
COMPLETE UPDATED LIST AS OF 7/27, I deleted all sold items from this list to make room
I take PayPal, Money Orders and Cash only, no checks.
I prefer local pickup but will ship any item at your expense.
My email is: [email protected],
My cell phone is: (508) 243-4752,
The car is located in Norton MA.
Car must be completely gone before Labor Day, so make an offer on any part.
Exterior Body Parts and Pieces:
Hood with vents, no dents, scratches, Perfect! And a perfect underside mat (Maroon) $250
Drivers side door assembly complete (No Mirror) (Maroon) $225 Reduced $175
Passenger side door assembly complete (No Mirror) (Black) $200 Reduced $150
Passenger side door hinge set $10
Passenger side electric window motor and regulator $25 Sale Pending Payment
Rear hatch key latch $15 Reduced $10
Rear hatch rubber seal $15
Rear bumper skin (Minor scratches) (Maroon) $100 Reduced $70
Rear bumper egg crate reinforcement bar $40 Reduced $30
Rear bumper driving lights lens $8.00 each
Rear Taillight- lens-Left $80 Reduced $20 Sale Pending
Rear center section (Plain) $40 Reduced $10
Drivers side electric motorized mirror w/mount perfect condition (Black) $75 Reduced $65
Drivers side electric motorized mirror without mount (Maroon) $55 Reduced $20
Pass side electric motorized mirror w/mount perfect condition (Black) $75 Reduced $65
Grounds effects/side skirt drivers side (Maroon) $40
Rear quarter panel (Cut out replacement) (Black)$75 Reduced $40
Passenger side rocker panel (cut out replacement) (Black) $40 Reduced $20
Perfect drivers side rocker panel (you cut out) (Maroon) $45 Reduced $30
Perfect Drivers side Rear quarter panel or rear clip (you cut out) (Maroon) $70 Reduced $50
T-top roof steel (you cut out) $70 Reduced $45
Complete front frame clip, You cut it off $125 Reduced $100
OR make an offer for the complete body shell.
Interior Items and Parts:
Drivers seat rails and track $20 Reduced $15
Passenger side seat rails and track $20 Reduced $15
Rear leather seats (TAN) $90 Reduced $60
Center console complete assembly including shifter plastic plate $100 Reduced $75
Emergency brake handle assembly and single cable $20
Steering wheel with radio controls $40
Steering column Tilt type with VATS ignition key and turn signal stalk controller and all electrical connectors intact ready to install $100 Reduced $80
Shifter Rubber boot $10
Dashboard pad assembly with passenger air bag, perfect condition $175 Reduced $150
Dashboard AC/Heat vent assembly $40 Reduced $35
Dashboard glove box assembly $30 Reduced $25
Dashboard Knee bolster drivers side $15 Reduced $10
Dashboard Knee bolster passenger side $10
Dashboard complete instrument cluster showing 80K $150 Reduced $125
Dashboard instrument cluster trim ring $20
Dashboard radio/HVAC trim plate $18
Heater and AC Dashboard control panel $35 Reduced $25
Subwoofer power amplifier $25 Reduced $20
Rear quarter area speakers $15 each
Drivers door speaker $10
Rear cargo area hinged cover (Tan) $40 Reduced $35
Carpeting has no rips and is in fair shape $85 Reduced $30
Cargo area grey carpet, great condition $30 Reduced $20
Cargo area T-Top storage plastic holders $20
Drivers side switch panel (broken door latch) $15 Sale pending
Drivers side threshold and kick panel (TAN) $20 Reduced $10
Passenger side threshold and kick panel (TAN) $20 Reduced $10
Drivers side rear quarter/seat panel (TAN) $20
Passenger side rear quarter/seat panel (TAN) $20
Drivers side rear sail panel with speaker (TAN) $25
Passenger side rear sail panel with speaker (TAN) $25
Rear Hatch bottom interior panel, some scratches (TAN) $15 Reduced $10
Rear Hatch side/top panels L&R pieces (TAN) $10 for both
Drivers seat plastic side and rear piece with netting pouch TAN $20 Reduced $10
MAKE AN OFFER FOR ALL THE ABOVE TAN INTERIOR TRIM PANELS
Passenger Front seatbelt (TAN) $20 Reduced $10
Rear seatbelt assemblies (TAN) 15 each Reduced $10
Rear quarter speaker grilles $5 each
Interior under dash sound panels $8 each
DERM Diagnostic Energy Reserve Module, air bag controller computer $30
Air Bag sensor module from center console $20 Reduced $15
Air Bag sensor Module from dashboard $20 Reduced $15
Air Bar Sensor from front radiator support bar $40 Reduced $20
Steering wheel Air bag $40 Reduced $35
EBCM Electronic Brake Control Module, ABS computer $120
TDM Theft Deterrent Module for VATS system $15
Keyless Entry Receiver module, reprogrammable no remotes $15
There are more modules and relays I will identify and list, ask and I’m sure I have it.
Suspension, Brakes, Motor, and other parts:
Posi rear end, complete unit with panhard arms and cross arms, brake lines. Speed sensor etc. $250 Reduced $200 disc brake version, junk yards want $350-$550
Rear disc brake calipers $70 for both sides Reduced $50
Rear springs $30 Reduced $25
T56 torque arm $50 Reduced $25
T56 torque arm bracket and rubber mount $15
T56 transmission mount plate/crossmember $45 Sale pending
T56 master clutch Cylinder $45 Sale pending
T56 slave clutch cylinder $30 Sale pending
T56 Clutch reservoir and hydraulic braided hose $20 Sale pending
T56 Stock shifter $25
Front disc caliper and rotors, pads $60 per side
Master brake cylinder $30
Master brake power vacuum booster $45 Reduced $35
Complete Clutch, brake, and accelerator pedal assembly with all sensor/switches, perfect for the auto to manual transmission conversion $120
Bosch ABS Brake control module with bracket $40 Reduced $30
Cruise Control controller module with cable and mount $50 Reduced $40
LT1 motor mounts AND brackets $30
LT1 stock exhaust manifolds with EGR crossover tube $75 Reduced $50
Stock “Y” pipe cut off at Cat $10
Cat back pipe $15 Reduced $10 Cut off at muffler
LT1 Electric Air pump assembly with hoses $40 Reduced $30
LT1 Air intake rubber elbow small tear under clamp, doesn’t leak $20 Reduced $10
LT1 complete stock air cleaner assembly and hose and filter $25 Reduced $20
LT1 K member $45 Reduced $30
Front passenger side steering spindle (NEW) $35
Front drivers side steering spindle $10
Front springs $30 for both
Front shock bump stops $5 each
Front right shock upper control arm rubber mounts and plate $20
Front upper and lower control arms $40 for all Reduced $20
Power steering pump and hoses $75 Reduced $50
Power steering fluid reservoir complete $20
Battery tray and radiator overflow bottle $13
Rear sway bar $20 (not removed yet)
Almost new radiator $100 Reduced $90
Almost new AC condenser with $90 hose
Plastic shroud for radiator area $20 for both upper and lower pieces Reduced $10
Radiator upper mount plastic panel $30 Reduced $20
AC Compressor and hoses $175
Windshield washer reservoir and pump $35 Reduced $20
Stock 16" rims $250
Thanks,
Greg
ALL PRICES ARE NEGOTIABLE
Thanks,
GregLast edited by gvincent; 07-27-2007 at 04:24 PM. Reason: Some parts sold, MORE PARTS ADDED
06-27-2007, 10:38 PM #2
06-28-2007, 12:48 PM #3Junior Member
- Jun 2007
- New Jersey
- iTrader
- 1 (100%)
might be interested in the cooling fans and the drivers interior door panel. If you could a picture of the door panel would be appreciated. You can send to [email protected] .
Thanks
Bill
06-28-2007, 01:57 PM #4Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
I am leaving work now and will send you pics in 2 hours.
Thanks,
Greg
06-28-2007, 05:43 PM #5Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
Bill, The pictures you asked for have been sent.
Update the Rear Hatch and Spoiler have been Sold.
Thank you Chris,
Greg
06-29-2007, 02:52 PM #6Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
UPDATE:
Catalytic converter SOLD Pending Shipping
Rack and Pinion SOLD Pending Shipping
Drivers interior door panel SOLD Pending Shipping
Dual fan assemly SOLD Pending Shipping
I will attempt to update the list or post daily if neccessary
Thank you,
Greg
06-30-2007, 02:28 AM #7Junior Member
- Jun 2007
- Raleigh, NC
- iTrader
- 0
Silver- 1997 Trans Am
Greg, I will call you later on today to inquire about some parts.
Thanks,
Nelson
919-523-7009
06-30-2007, 05:05 AM #8Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
Nelson, Call my cell# (508) 243-4752 or my Home number (508) 285-8777 as I will be in and out all day removing parts, searching for boxes, and getting shipping quotes.
Thanks,
Greg
06-30-2007, 12:07 PM #9Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
Bill, (bonesbrakr) Your parts are all packed, I need your full name and address to get a UPS quote for shipping.
Thanks,
Greg
06-30-2007, 12:18 PM #10Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
Nelson,
Nice talking with you, email me your list and I will give you a discount. If you need pictures of anything let me know. You can see the headlights and the broken plastic bar in the pictures in the first post. I have since removed the headlight assemblies and threw out the plastic bar which was cracked at both intersections as I mentioned on the phone.
Talk soon,
Greg
07-01-2007, 10:57 PM #11Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
BUMP, I updated the list
Thanks,
Greg
07-02-2007, 06:33 PM #12Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
Bill, (bonesbrakr) your items have shipped, I sent an email to you with the tracking numbers.
Thanks again,
Greg
07-03-2007, 09:07 PM #13Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
Nelson, I sent you an updated list with prices
Thanks,
Talk later,
Greg
07-05-2007, 08:46 AM #14Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
The Parts list has been updated, I added some more parts, reduced the prices of some, and marked the pending sale and sold items.
Please remember that ALL PRICES are negotiable, I had to post a price to all the items and some are really wild ass guesss.
So don't be afraid to ask. I will do quantity and package pricing if buying more than 1 item.
Thanks,
Greg
07-05-2007, 08:48 AM #15Senior Member
- cincinnati/northern ky
- iTrader
- 0
Black- 99 SS
PM sent
07-06-2007, 10:01 AM #16Senior Member
- Feb 2006
- Orange County, NY
- iTrader
- 0
do you have the battery tray still? how much?
07-06-2007, 10:14 AM #17Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
Yes I still have the battery tray, I haven't removed it yet. I'll remove it tonight and send a picture. What's your email address?
07-06-2007, 10:45 AM #18Senior Member
- Feb 2006
- Orange County, NY
- iTrader
- 0
[email protected]. thanks
07-07-2007, 08:08 PM #19Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
Ron,
I sent you a pic of the battery tray/overflow bottle
Thanks,
Greg
07-11-2007, 01:09 PM #20Member
- Oct 2006
- Norton MA
- iTrader
- 3 (100%)
Black- 1976 280Z V8
Zboner,
We are all set, I sent you emails,
I will ship the items tonight and send you a tracking number,
Thanks,
Greg
1995 Pontiac Firebird Trans am Ram air (Project)
By Cargod9373 in forum Vehicles For Sale / TradeReplies: 7Last Post: 09-20-2007, 05:14 AM -
1995 Firebird Trans am Ram Air LT1 Auto----Project.
By Cargod9373 in forum Vehicles For Sale / TradeReplies: 0Last Post: 09-18-2007, 10:18 AM -
F/S 1995 Firebird Formula LT-1 6 speed trans
By fredg369 in forum Vehicles For Sale / TradeReplies: 5Last Post: 12-12-2005, 05:37 PM -
F/S 1995 Firebird Formula LT1 6 speed trans
By fredg369 in forum Eastern MembersReplies: 6Last Post: 12-10-2005, 08:23 AM -
Fs: Parting out 96 Firebird Trans am
By MyTyphoon1993 in forum Parts For Sale / TradeReplies: 7Last Post: 09-28-2005, 07:00 AM
