Thread: shifting problems!
06-27-2007, 04:37 PM #1
shifting problems!
i have a 98 camaro z28 and when i smash on it,it seems to get stuck when i try to switch gears,any ideas on what it could be???clutch cable adjustment mayb??let me know,thanx
06-27-2007, 08:17 PM #2
hydraulic clutch, no cables involved
06-28-2007, 08:07 AM #3Junior Member
- Sep 2005
- Michigan
Onyx Black- 2000 Berger SS #21
06-28-2007, 10:05 AM #4
the clutch is good,when i shift its hard to get it into gear
06-28-2007, 10:17 AM #5
that could mean the clutch is bad not good. if the clutch isnt fully disengaging then it will not let you go into gear properly. and forcing it into gear will only damage your key ways leading you to a rebuild. How old is the clutch? what brand clutch? how many miles?
If your Shifter is stuck in any gear.....You have a damaged blocker ring, broken slider key or a damaged shift fork. While the blocker ring and fork are possible problems, 99.9% of the time the slider keys is broken and is what causes all of your problems. You can not fix any of these issues without rebuilding the unit. If you continue to drive it with it damaged, you run the risk of causing gear damage to that specific gear and then will further progress to other gears and the rebuild process is more expensive.Last edited by Raven02ta; 06-28-2007 at 10:25 AM.
May have shifting problems
By ChevyZ76 in forum Camaro / SSReplies: 13Last Post: 06-12-2014, 06:30 PM -
Help: Shifting problems on my 98 Ls1
By speedracer25f in forum Automatic TransmissionReplies: 10Last Post: 02-05-2010, 01:06 PM -
Problems Shifting
By ERICV82GO in forum Manual TransmissionReplies: 5Last Post: 09-23-2008, 07:01 PM -
shifting problems...
By suede in forum Manual TransmissionReplies: 3Last Post: 08-21-2007, 08:55 AM -
shifting problems!
By camarossf650 in forum Manual TransmissionReplies: 6Last Post: 06-28-2007, 07:27 PM
