Thread: A smaller muffler than stock.
06-27-2007, 02:18 PM #1
Will a smaller than stock muffler cause more backpressure? The smaller muffler is about 6 inches shorter and it has a wide-open flow. Just need info on the backpressure.
06-27-2007, 04:48 PM #2
depends on the inside of the muffer. you said its a wide open flow so it'll probably lower backpressure, oem mufflers are pretty restrictive. what kind is it?
2002 Z28 M6, Suncoast Creations ram air, port/polish TB w/ bypass and bumpstop, heater hose mod, stainless steel long tubes, ORY w/ dual cutouts, Magnaflow, BMR SFC, UMI Torque Arm, LS7 clutch w/ drill mod, Pro 5.0 w/ Lous short stick, MSD wires, 4.10s, good maintenancehttp://www.fquick.com/blue02z
06-27-2007, 06:13 PM #3
06-27-2007, 06:26 PM #4
If the muffler is straight through and same size as the rest of the exhaust, regardless of its length, it will not cause any backpressure.
06-27-2007, 07:44 PM #5
06-28-2007, 09:14 AM #6
anyone repalce there stock cme muffler?
By SLP02SS in forum External EngineReplies: 10Last Post: 05-15-2008, 03:23 PM -
Gutted stock muffler.
By SS-Power in forum External EngineReplies: 10Last Post: 07-18-2007, 03:51 PM -
Which muffler to replace stock muffler
By casino187 in forum External EngineReplies: 6Last Post: 07-23-2006, 02:37 PM -
Looking for a stock muffler
By phoff in forum Parts Wanted / TradeReplies: 5Last Post: 03-14-2006, 10:41 AM -
Is stock SS muffler that restrictive?
By In_style in forum External EngineReplies: 2Last Post: 08-13-2005, 08:52 AM
