Thread: car is acting up
06-27-2007, 09:51 AM #1
car is acting up
After i did seafoam in my car the car once in a while starts up and then idles at like 350-400... then i turn it off and wait like 3 minutes and then start it up and it goes back to normal... what does everyone think??
06-27-2007, 10:26 AM #2
06-27-2007, 10:40 AM #3
Idle air control valve may be going out.
06-27-2007, 11:12 AM #4
I put a little in the gas tank the rest in the crankcase... where is the idle air control valve at? and how much is it to replace...
06-27-2007, 11:18 AM #5
Actually now that I think about it, maybe it is the fuel filter like jad628 said. If the filter is really clogged, then it may take a couple of tries for the fuel to push through the restriction on a cold start. I would try changing the filter first, since it probably needs to be done anyway. The idle air control valve would probably set a code, however, I have seen them act up without setting a code. Is the service engine soon light on? The idle air control valve is located on the throttle body.
06-28-2007, 08:42 AM #6
soo where is the fuel filter located at??
06-28-2007, 09:33 AM #7
under the car, driver's side in front of rear wheel.
HELP!! system acting up
By midnightnavyz28 in forum Stereo and ElectronicsReplies: 2Last Post: 04-11-2009, 08:35 AM -
speaking of acting....
By DrMilhouse in forum Almost Anything GoesReplies: 3Last Post: 07-20-2008, 10:54 PM -
cars acting up
By 1fastgto in forum GTOReplies: 14Last Post: 07-10-2007, 07:45 PM -
Car Alarm acting up...
By 01RaptorTA in forum Stereo and ElectronicsReplies: 14Last Post: 03-25-2007, 05:27 PM -
need help car is acting funny
By rshooch in forum General HelpReplies: 3Last Post: 09-09-2005, 04:52 PM
